Updated Thermwood QuickCut Video
Posted by Duane Marrett on Fri, Sep 04, 2009
Tags: Thermwood, CNC, software, CNC Routers, 3 Axis, Announcements, CabinetShop, Cabinet, smart, Video, nested based, QuickCut, 43, Easy, super controller
We've created an updated QuickCut video that shows how easy and powerful the entire process is:
About QuickCut:  QuickCut is available on all Thermwood CabinetShop series machines and offers the fastest, easiest and simplest possible way to make custom cabinets. Everything is done right at the machine. You don't need separate computers, design software, networks or anything else other than the machine.
Please Click Here for more information on QuickCut
Thermwood Introduces Low Cost, High-Performance CabinetShop 43
Posted by Duane Marrett on Wed, Sep 02, 2009
Tags: Thermwood, CNC, New, 3 Axis, Announcements, CabinetShop, Model 43, Technology, Cabinet, High Performance, Cost, cabinets, QCore, nested based, QuickCut, closets, 43, Low Cost, manufacturing, Ken Susnjara
We are pleased to introduce a revolutionary new CNC Router System, called the CabinetShop 43, for nested based applications. This new high performance CNC router is built in the US, at Thermwood's Southern Indiana factory and utilizes a whole new, highly efficient manufacturing approach which results in a superior structure coupled with enhanced use of materials, all at a dramatically lower price.
CabinetShop 43
The new machine features a 61 by 121 inch fixed table, a 10 HP HSD spindle and an eleven position automatic tool changer. It offers high acceleration, high performance motions in both positioning and cutting. This new system includes quality features seldom, if ever, found at this price point including full stress relieved weldments, high-end Siemens drives throughout, THK rails and three-dimensional volumetric position compensation.
The system also includes Thermwood's QCore SuperControl which sharply distinguishes it from every other machine in this class offering features such as:
"QuickCut" is the fastest, simplest, easiest way to make cabinets and closets ever. Just select and resize a cabinet from the library and cut it, all right at the machine control.
"Job Level Interface" means you communicate with every major cabinet design software package using a single job file instead of dozens or hundreds of individual programs. Nesting and program development happen automatically at the machine; an approach that offers dramatically simpler operation and higher productivity.
The QCore SuperControl also executes standard G-Code programs developed elsewhere.
The QCore SuperControl also has an impressive list of operating features all with one purpose, make the machine as foolproof as possible to reduce errors, minimizing the time you fiddle with the machine. It runs more with less effort.
- Automatic Tool Management helps you manage tooling and tracks tool life
- Maintenance Tracking tracks machine use and guides you through routine maintenance
- Graphic Error Reporting shows you exactly where a problem is and suggests solutions
- Complete User Manual in the control
- Dynamic CAD drawings of the entire machine on the control screen
- Maintenance Videos on the control guide you through mechanical adjustments
- Virtual Service provides direct link from the control to Thermwood service
Never before has this level of technical sophistication, quality and performance been available at this price. The CabinetShop 43 is ushering in a new era of productivity, ease of use and profit for custom cabinet operations.
Adirondack Studios completes project using Artcam, Thermwood
Posted by Jason Susnjara on Fri, Aug 28, 2009
Tags: Thermwood, CNC, software, CNC Routers, 3 Axis, manufacturing, Skills, artcam
Delcam's ArtCAM software enabled Adirondack Studios to complete successfully a project to produce five giant chandeliers for the Mohegan Sun Casino at Pocono Downs, Pennsylvania.
For over 30 years, Adirondack Studios, based in Argyle, New York, has helped to design and build themed environments for theatres, arenas, exhibit halls, ballrooms, parks, restaurants, casinos, amusement parks, supermarkets, museums, stadia and marinas. About a year ago, the company began using the ArtCAM artistic CADCAM software to program the CNC routers used to manufacture the majority of the company's products.
"The software that we used in the past for CNC programming worked fine for routine jobs but many of the projects that we get involved in are far out of the ordinary," said Bob Gregory, Senior Router Operator. "We spent too much time watching the clock while we were machining and ran into quite a few bugs. Also, the software developer was not as responsive as we wished when we called in for support."
"We had heard that a number of our competitors were using ArtCAM with very good results so we decided to give it a try," Mr. Gregory continued. "From the very beginning we felt that ArtCAM was a more finished product, more robust, with much higher performance. The tutorials make it very easy to take advantage of the many advanced features of the software. The support provided by Delcam has been superlative and they do listen to, and implement, user suggestions for improving the software."
Adirondack Studios' designers began the construction of the chandeliers by building a 3D model in AutoCAD. The file was imported into ArtCAM to generate the CNC program to machine a positive shape in low-density foam. This was used by a subcontractor to vacuum-form the plastic bowl segments. These were then painted to look like alabaster.
In a similar way, the casting department used ArtCAM to make a mould to cast the grouse models that would be used to decorate the chandeliers. A black-tinted silicone rubber was used to give the grouse the appearance of wrought iron.
The next step was to create a bird's nest pattern and weave it around the circumference of the bowl. ArtCAM allowed the ways in which the strands crossed each other to be varied for a more natural appearance. "Birds do not use a CNC machine to build their nests so it took considerable effort to get the correct look," Mr. Gregory said.  Mr. Gregory generated a CNC program to cut the bird's nest negative shape into MDF. It took only fifteen minutes to create the program compared with at least four hours that would have been needed with the previous software. The mould was used to cast the bird's nests from the same silicon rubber used for the grouse. Finally, the birds and the nests were glued to the bowl of each chandelier.
The finished chandeliers were then installed in the casino. They formed part of a $208-million renovation of the site, aimed at transforming it into the area's leading entertainment complex.
Thermwood Joins the American Wind Energy Association!
Posted by Duane Marrett on Thu, Aug 27, 2009
Tags: Thermwood, CNC, Composites, CNC Routers, 3 Axis, 5 Axis, Announcements, Trade Shows, Product Information, manufacturing, Wind Energy
We are now a Business Member of the American Wind Energy Association (AWEA), and will be exhibiting at the Windpower Expo 2010 in Dallas, TX (May 23rd-26th, 2010).  Make plans now to come out and see us in action.
Thermwood is a Business Member of the American Wind Energy Association
Thermwood offers 3 and 5 axis systems ideally suited for the production, fabrication and trimming of composites and other materials used in the production of wind energy products.
For more information on our applications in this area, please visit the composite page of our CNC Routers By Applications area.
New Low-Cost, High Performance CabinetShop 43 5×10 CNC Router Coming Soon!
Tags: CNC Routers, 3 Axis, Announcements, CabinetShop, Model 43, High Performance, Cost, 43, Low Cost
CabinetShop 43 Coming Soon!
We are pleased to announce the upcoming arrival of our latest machine, the CabinetShop 43! This low-cost, high-performance 5×10 table CNC Router is perfect for making nested based cabinets, closets, furniture and upholstered frames.
Look for more information about the CabinetShop 43 coming in the next few weeks.
Until then - if you would like to know more, please contact us for the inside scoop.
Thermwood announces QuickCut Cabinet and Closet System
Tags: Thermwood, New, CNC Routers, Productivity, Woodworking, 3 Axis, Announcements, Cabinet, cabinets, Product Information, Assembly Marks, Gen2, QuickCut, Closet, closets
We are pleased to announce a new, simplified approach to nested based production of cabinets and closets that does not require separate cabinet design software. This new approach, called "QuickCut", is done entirely at the CNC machine.
QuickCut Screenshot
The operator, working at the machine control, simply selects and resizes cabinets and closets from a built-in library and runs them. This entire process happens at the machine. The process is simple enough that virtually anyone can run it with minimal instruction. Libraries can be modified or extended through a programming service.
"For the first time you can operate a CNC router without extensive training or technical skill", says Thermwood's Vice-President of Marketing Jason Susnjara. "This approach allows cabinetmakers to focus on making cabinets using an amazing new tool that's really easy to use".
Operating a CNC router usually requires specialized knowledge which limits its use to specially trained employees. We used the technical power in our Gen2 SuperControl to totally automate virtually every task, then created a simple user interface, resulting in a system that almost anyone can use without extensive training.
The QuickCut feature targets smaller, less technical shops but can also be used by larger companies to make virtually any part or product in their product line any time they want. A library of parts can be stored on a network drive. At that point, almost anyone can walk up to any QuickCut machine and make any part. It's that easy. By storing files in a central location, management has complete control of anything that is made, anywhere in the factory.
"This new interface takes what has been a confusing area for non-technical users and makes it almost as easy as using a copy machine", states Thermwood's President, David Hildenbrand. "We believe it will fundamentally change how cabinets, closets and perhaps many other products, are made".
All nested based systems from Thermwood are QuickCut compatible and Gen2 systems operating in the field can be retrofitted to make them QuickCut compatible.
For more information on this exciting new development, please visit our QuickCut area of the website.
New web interface for 3 and 5 Axis CNC Routers
Posted by Duane Marrett on Fri, Aug 21, 2009
Tags: Thermwood, CNC, New, CNC Routers, 3 Axis, 5 Axis, Announcements, Model 90, Model 67, Model 70, Model 45, MTR, Model 41, Model 53, Model 40, Model 42
We've just completed updating and expanding our 3 and 5 axis CNC Router areas on thermwood.com.
This new interface allows a wider variety of information to be accessed easily and more quickly than our previous version, and lists images, dimensional drawings (which can be easily printed), technical specifications, movies of the machines in action and brochures all in one convenient place.  I've included some screen shots below - to visit, please click on either:
3 Axis CNC Routers
5 Axis CNC Routers
Thermwood's New CNC Router Interface on www.thermwood.com
Thermwood Production Sharing Members added to Google Earth
Posted by Duane Marrett on Thu, Aug 13, 2009
Tags: Thermwood, eCabinet Systems, CNC Routers, 3 Axis, 5 Axis, Announcements, Production Sharing, Google Earth
Thermwood Production Sharing Members Mapped in Google Earth
 A cool thing we've just completed is adding our Production Sharing Members to Google Earth.  Google Earth is a free download, and once you have it, you can click on the Production Sharing Members map of your choice and view all of the Members that list their services on an interactive map.  This tool allows you see see at a glance Members who are in your area.
For more information, please visit the Production Sharing Area our website.
About Production Sharing - This is a free listing service that Thermwood offers any of our CNC Router Owners where they can list their production services and allows any eCabinet Systems Member or other interested parties to contact these Production Sharing Members and have their jobs machined out on a CNC Router quickly and cost-effectively.
Purdue Student Wins First Place in Furniture Design Contest at AWFS
Posted by Duane Marrett on Fri, Jul 24, 2009
Tags: Thermwood, CNC, 3 Axis, Trade Shows, AWFS, Furniture, Winner, Prize, Student, Purdue
Purdue University has two Thermwood routers, and recently had a student win first place in furniture design at AWFS:
Leah Kenttamaa Squires, a student at Purdue University, West Lafayette, recently received a First Place Award for her entry SAKURA HANA in Fresh Wood, a national competition for woodworking projects sponsored by the Association of Woodworking and Furnishings Suppliers (AWFS). Judges Dan Hershberger, AWFS Board Member, left) and Randy Johnson, editor, American Woodworker (right) presented Kentamaa-Squires with her award at AWFS Fair 2009, in Las Vegas, NV.
Leah Kenttamaa-Squires created this award-winning piece in a class Furniture Design for CNC Manufacturing in Fall of 2008, under the leadership of professors R. Gazo, E. Haviarova, R. Paul and Wood Research Laboratory technician D. Warner. The course is a joint effort between the Department of Forestry and Natural Resources and the School of Visual and Performing Arts.
The 50 finalists were chosen from 169 entries from 49 different schools in North America. Hongtao Zhou a former Purdue student who graduated in 2008 from the same program and now teaches design at University of Wisconsin in Madison received an Honorable Mention at the same competition.
Thermwood CNC Routers optimize cooling tower builds
Posted by Duane Marrett on Mon, Jul 20, 2009
Tags: Thermwood, CNC, Composites, CNC Routers, Productivity, 3 Axis, Technology, Customer, manufacturing
Here is a reprint from an informative article published in Composites Technology about Bedford Reinforced Plastics and their application of Thermwood CNC Routers in cooling tower fabrication:Thermwood CNC Routers used in the fabrication of cooling towers
Operators of chemical refineries, mining operations and power plants use cooling towers to reduce the temperature of process water that often contains corrosive chemicals. These large square or rectangular structures house equipment in which heated water trickles downward through filtration media while large fans draw air up through the wet media to transfer the heat to the atmosphere. Although cooling towers traditionally have been made with wood and concrete, composite materials are gaining acceptance due to their corrosion and rot resistance, light weight and ease of installation. "Redwood was used in the past because of its innate ability to resist rot. But, as good redwood became scarce, treated Douglas fir was substituted, and in addition to the negatives associated with the chemicals used to treat the wood, fir just couldn't hold up in the cooling tower environment," says Eric Kidd, cooling tower market manager at Bedford Reinforced Plastics (Bedford, Pa.).
Bedford has pultruded square tubes, angles, channels and deck board for cooling tower alternatives since the mid-1990s, says Kidd, including one of the world's largest - a 46-ft tall, 54-ft wide, 1,080-ft long (14.2m by 16.6m by 332m) structure at Barrick Goldstrike Mines Inc. in Carlin, Nev. Bedford supplied more than 600,000 lb (272 metric tonnes) of pultruded components made with Owens Corning Material Solutions' (Toledo, Ohio) continuous filament mat and E-glass roving, Ashland Inc.'s (Columbus, Ohio) fire retardant polyester and vinyl ester resins and polyester surfacing veil. Drilling the thousands of fastener holes and cutouts that enable assembly and fastening of the tower's skeletal structure is a huge challenge. For that task, Bedford employs five 3-axis, CNC-controlled routers from Thermwood Corp. (Dale, Ind.). Configured with overhead moving gantries, the machines have bed sizes that range from 5 ft by 10 ft (1.5m by 3m) to 5 ft by 40 ft (1.5m by 12.2m). According to VP of marketing Jason Susnjara, Thermwood is the only CNC router manufacturer that supplies its own controller programs with the machines, enabling customers to seamlessly integrate CAD/CAM designs with the controller and postprocessor.
Bedford considers automated drilling and cutting to be essential to optimizing finished-part production rates, hole consistency and location accuracy. The former, says Bedford, reduces product lead time, permitting the company to meet tight customer deadlines. The latter ensures that tower structures assemble correctly on site, without delays for part rework.
