Thermwood Mastercam 3 Axis Post Updates
Changes/Additions for Version X.4.6
27.4.6 – for Mastercam 2027
26.4.6 – for Mastercam 2026
  • Fixed- Vertical aggregates not outputting correct C axis code if first motion after plunge is an arc.
  • Fixed- If Adjustable Head Spacing (Misc Real 2) had more than 4 decimal values, each continuation of an operation would output all of the tool change information again.
  • Fixed- When saving posted code, if the file type was set to all files and the name had no extension the saved file name would have ..nc or ..sub.
  • Fixed- Dual headed files did not output all the tools in the tool table in certain scenarios.
  • Fixed- Spindle off at tool change was not output for dual headed tool changes in certain scenarios.
  • Fixed- Radius Compensation in Control for Helix Bore and Slot Mill toolpaths wasn't turning on until after reaching top of stock.
  • Modified- Print on Material only calls the cartridge changes that are needed instead of every cartridge.
  • Modified- Moved the adjustable head axis motion from it's own line to the same line as the X and Y positioning motion.
  • Modified- Break positioning motions into XYC and then Z for aggregates when new operation or when the C value changes between the start and the end of contours in the same operation.
  • Modified- Aggregate clearance values are not output when using a safety zone inside an operation or when using Multiaxis linking to combine operations into one operation.
  • Added- When a file is set to output a sub file, Table redirect/tie information is added to the file after the head redirect is turned off. The variables match the variables used in the dual table application on the controller. This previously only happened if the file was set for multiple table.
  • Added- If the Clearance, Retract, or Feed planes in linking parameter are set to absolute and are a lesser value than the top of stock a warning will appear on screen.
  • Added- Start of New Operation post block added to unencrypted mcpost file.
  • Added- Acceleration Macros, Tangency, Arc Speed, and Smoothing Factors added in Misc Reals for each operation. The values in the postcon.exe are still used for setting the values globally at the beginning of the file.
Changes/Additions for Version X.4.5
27.4.5 – for Mastercam 2027
26.4.5 – for Mastercam 2026
  • Fixed- Create file as sub did not overwrite existing sub file.
  • Fixed- Print on Material with a single comment was ignored
  • Fixed- Print on Material when comment was the color Black was ignored
  • Fixed- when using a drill block with a null toolchange, outputs for drill block were not output until after the first plunge and retract.
  • Fixed- Multi sheet count was incorrect if using multiple materials.
  • Fixed- Multi sheet using multi materials would not add sheet ending to last sheet on first material and all subsequent sheets.
  • Added- Print on Material only prints comments if they are on a visible layer.
  • Added- Print on Material can separate by color cartridges Red Yellow Green Blue Black in that order or print all labels in a single undefined color. White can be substituted for black when using a dark background.
  • Added- User Defined Variable Use_G79 has been added so that aggregate clearances can be set relative to machine coordinates instead of relative to the fixture offset.
  • Modified- Moved the vacuum input check from right before the plunge into the material to right after the XY positioning move at the beginning of each operation.
Changes/Additions for Version X.4.2
26.4.2 – for Mastercam 2026
25.4.2 – for Mastercam 2025
24.4.2 – for Mastercam 2024
  • Fixed- Coolant not turning on when using helix entrance in pocketing.
  • Fixed-Spindle up to speed code M31 not outputting to file when using dual head forced tool change with Z clearance before positioning move.
  • Fixed- Coolant turning off after a manual entry instead of before.
Changes/Additions for Version X.4.1
26.4.1 – for Mastercam 2026
25.4.1 – for Mastercam 2025
24.4.1 – for Mastercam 2024
  • Added- comment to Z clearance first line to define it as on Misc Int 5
  • Added- comment to [USEFIX1] to define custom z offset
  • Added- comment on vertical aggregate operations at the beginning if set to rotate 180 every other cut
  • Fixed- Clearance heights for aggregate tooling was outputting incorrect values.
  • Fixed- Vertical aggregates not simplifying C axis correctly in certain circumstances.
  • Modified- postcon.exe not found error to add information about antivirus possibly deleting it.
  • Fixed- Coolant not turning off in specific situations.
Changes/Additions for Version X.4.0
26.4.0 – for Mastercam 2026
25.4.0 – for Mastercam 2025
24.4.0 – for Mastercam 2024
  • MODIFIED- The post version numbering format has been modified to allow the most current post to be used in Mastercam 2024, 2025 and 2026.  Format: X.Y.Z    X= Mastercam Version  Y= Post Major Version  Z=Post Minor Version.
  • MODIFIED- Both Mastercam Router and Mill now ue the same .control and .mcpost files to simplify support.
  • MODIFIED- Vertical Aggregates must be defined as an aggregate tool now to output the C axis rotation information.  This is so any/all aggregates used on the machine are setup in the tooling the same way.
  • MODIFIED - Saw tools must be setup as an aggregate tool now to output the C axis rotation information. Aggregate body and tool length Information needs to be setup in Mastercam’s Machine Definition. This is so all aggregates used on the machine are setup in the tooling the same way.
  • MODIFIED - Scorecomp variable was removed from the post. Saws are now setup as aggregates so adjustment for the saw body is done automatically now.
  • MODIFIED- all aggregates are now a purchased add-on feature for the post processor.
  • MODIFIED - Changed the print on material output to work with multiple formats defined in the post processor.
  • FIXED- Manual Entry inserted after tool call not outputting correctly if manual entry is first operation.
  • FIXED- Outputting the file as a sub could cause non-critical errors to be recorded in certain scenarios.
  • ADDED- Support for adjustable angle aggregate routers. Aggregate body and tool length Information needs to be setup in Mastercam’s Machine Definition
  • ADDED- Support for right angle aggregate routers. Aggregate body and tool length Information needs to be setup in Mastercam’s Machine Definition
  • ADDED- Tool description in tool list updated to add aggregate information when an aggregate is used in the file.
  • ADDED- More detailed error messages when the postcon.exe application cannot be found or opened.
  • ADDED- if using Rotate Origin in the postcon.exe and a translated toolpath is set to output as sub file, an error will be displayed.
  • ADDED- If a translate/Mirror toolpath is set to output as a sub file and the mirror point is not at 0.000 on the axis an error will be displayed.
  • ADDED- When using custom fixture override and the restart at operation is on,  [USE_FIX] is output at all tool calls.
Changes/Additions for Version 25.01
For Mastercam 2025
  • Added- Saw toolpath can be used and will output the correct C axis value along with radius comp commands to offset for the aggregate body.
  • Added-Scorecomp variable in the post to define which radius comp call scoring is using when using a saw.
  • Added-Ability to use sub programs when using Drill, depthcuts, and transform operations.
  • Added- [GRAPHON] and [GRAPHOFF] commands in the check for vacuum code so the controller is not set in an infinite loop when graphing.
  • Added-right angle aggregates can now be used for programming. Operations must be either a multiaxis toolpath set for 4 axis with rotary around Z or a regular 3 axis tool path in a different plane with Rotary Axis Positioning and Rotate around Z axis both on. Aggregate body and tool length need to added into the aggregate/tool setup.
  • Added- sconfigfile variable in post that can be set to use a default configuration file to bypass the postcon.exe. The variable should be blank if the option is not to be used.
  • Added- if dual table is on but the table option is secondary table only and loop is off, Code output will not have the AFL selection for tables and the code will only reflect a redirect to the secondary table.
  • Fixed- operator message error when depth cuts use radius comp, keep tool down, operator messages, and restart.
  • Modified- Multisheet jobs will error out if print on material or print and apply labels is selected.
  • Modified- Changed how the print on material output is written to work with new formats.
For Mastercam 2025
  • Upgraded from version 24.3.2 to Mastercam 25 for Mastercam 2025.
Changes/Additions for Version 24.3
For Mastercam 2024
  • Fixed- missing positional motions in certain circumstances.
  • Fixed- operator messages header was not output if file was set to incremental sub mode.
  • Fixed-operations count now counts all drill holes instead of grouping them into 1 operation
  • Fixed-surfacing operations with clearance on at beginning and end only skipped XY rapid moved and combined it with the Z causing ramping cuts into parts
  • Added -Multi Sheet files can now be output into one file if needed.
  • Modified- operator messages now output a drill range for drill operations
  • Modified- operator messages now output the extended operation identifier
  • Modified- ROTARY PLAYBACK TOOLPATHS ARE TURNED OFF FOR FURTHER WORK.
Changes/Additions for Version 24.1
For Mastercam 2024
  • Fixed- X and Y positions were not output after tool call if the previous ending position was the same as the current stating position
  • -Added- Modified Post and Postcon.exe to allow up to 20 vacuum input and outputs
Changes/Additions for Version 24.0
For Mastercam 2024
  • Upgraded from Mastercam 2023 to Mastercam 2024
  • -Fixed- Drill block output was broken in certain scenarios in 2022
  • -Fixed- Dual head coolant off output AFL variables after normal calls
  • -Modified- more detailed Gcode comments added
  • -Modified- Comments after any code are now spaced to the side to column 41. Full line comments still start at column 1.
  • -Modified- Clearance before or after the XY position move is now controlled by Misc integer 5.
  • -Modified – Manual Entries can now be placed after tool calls by adding T! prior to the code.
  • -Added- Drill block can output as can cycles now
  • -Added- C axis for vertical aggregates. Turned on using misc. integer 10 and controlled with misc. real 10.
  • -Added- POSTCON Check box to turn off the G code comments (learning mode OFF)
  • -Added- “drill block #1 output not set” error added for both primary and secondary drill banks.
  • -Added- Forced tool call customizable block similar to the pretool change post block.
  • -Added- Postcon.exe greys out rotation if drill bank is used in the file.
  • -Added- support for up to 4 vacuum zones in the post and Postcon.exe
  • -Added- Drill block1 can be defined to use the W axis now for AP43
  • -Added-Number of drills in vertical drill bank 1 is now definable for the smaller drill blocks
Changes/Additions for Version 23.0
For Mastercam 2023
  • Upgraded from Mastercam 2022 to Mastercam 2023
  • -Fixed- null tool change for Mill axis redirect information MI3$ read needs to be in the top of the block
  • -Fixed- change IF [(OPSTOP=1|OPSTOP=2)] THEN to IF [(OPSTOP=1)|(OPSTOP=2)] THEN
  • -Modified- Add2Footer information is now available inside the sub footer also
  • -Modified- Can Text output at tool calls works with Before, With and After now
  • -Added- Rigid tapping can cycle
  • -Added- ability to make add to header and footer multiple lines using /n
  • -Added- variable to set the clearance information back to the default X and Y and then Z
  • -Added- Checkbox in POSTCON.exe V20.4 to turn on/off the use of Can Cycles
  • -Added- Can Cycles to the post processor
  • -Added- pre and post tool change blocks have been moved outside of the binned area
  • -Added-Tool inspection post block have been moved outside the binned area so customer can add any commands they want to the inspection
