Thermwood Mastercam 5 Axis Post Updates
Changes/Additions for Version 5.5.0
27.5.5.0 - For Mastercam 2027
10/12/26
Fixed unnecessary or sub-optimal ±360° C-axis rotations immediately following vertical positions in posted operations. These changes are only applicable to posted files with a continuous C-Axis.
Improved continuous C-axis motion to minimize rotation between consecutive positions. While maintaining the 5th axis (A or B) orientation, the C-axis may reverse direction to reach the next position with no more than 180° of rotation.
Improved continuous C-axis motion following vertical positions. When permitted, the 5th axis (A or B) may use the opposite tilt direction to minimize C-axis rotation, limiting rotation to no more than 90° to reach the next position.
Changes/Additions for Version 5.4.1
27.5.4.1 - For Mastercam 2027
8/19/26
Fixed dual-table output issues associated with removeLoadPartStop. These changes ensure that removeLoadPartStop only disables the output of the associated AFL Program Stops.
Fixed dual-table AFL output issues related to positioning at Home/Park when tables are tied via AFL or with a control switch. Updated the Home and Park sequences to remove commands to the secondary table when tables are tied or redirected.
Fixed cutter/radius compensation output issues found in 2D “Circle Toolpaths.” These changes ensure cutter compensation is temporarily disabled while positioning between holes for the following toolpath types: Helix Bore, Circle Mill, and Slot Mill.
Changes/Additions for Version 5.4.0
26.5.4.0 - For Mastercam 2026
4/13/26
Modified default title for posted .NC files. As the first two digits denote the Mastercam version, redundant comments were removed.
Fixed logic in the C-Axis unwind routine and related functions to ensure ZTC position is reached prior to rotating Axis 4. This should resolve any issues allowing unwinds to be performed at the retract position when Safety Zones or Multi-Axis Linking is used.
Added post variable unwindDisableTCP to the “User Customization” region. This value can be used to temporarily disable TCP when unwinding the C-Axis during the default unwind routine.
Added post variables useCustom_PreUnwind and useCustom_PostUnwind to the “User Customization” region of the post. These variables can be used to enable/disable their corresponding postblocks pCustom_PreUnwind and pCustom_PostUnwind. Custom Unwind postblocks will be called during the default unwind routine after retract motion and before plunge motion respectively.
Changes/Additions for Version 5.3.0
26.5.3.0 - For Mastercam 2026
3/2/26
Fixed a logical error in the memory stack used to pre-process future positions of the 4th and 5th axis. This occurs when the tool becomes perfectly vertical at any point during 5-Axis operation. This change should resolve issues generating .NC with invalid orientations or that violate Misc. Integer values. This pertains to operations that start vertically and contain isolated motion of the 5th axis with the 4th axis at exactly 0 degrees.
Improved error handling for 5-Axis operations posted with a Tool Plane that is not “Top”. Like other error handling methods this will now display a notification to the user, corresponding operation #, and remove the incomplete .NC file being generated.
Changes/Additions for Version 5.2.0
26.5.2.0 - For Mastercam 2026
1/9/26
Added post variable use_tcpAngleLimit to the “Post Settings” region, allowing users to disable the tcpAngleLimit for the 5th Axis. If disabled, the 5th Axis “(Safety Angle)” will not be output in the resulting .NC file during applicable index motion.
Changes/Additions for Version 5.1.1
26.5.1.0 - For Mastercam 2026
12/5/25
Fixed C-Axis index motion logic to prevent positioning beyond 4th Axis limits at the start of operations. Additional modifications were made to allow the C-Axis to maintain its position for 3-Axis Top-Plane operations even beyond (C0, C360). These changes are only applicable to posted files with a non-continuous C-Axis.
Changes/Additions for Version 5.1.0
8/27/25
Fixed arc output errors from MP present when posting OptiRough operations. Changes ensure arc/helix motion will be output as G02/G03.
Added a new warning message to notify users when any posted operation has a relative T-Plane origin not shared with the WCS.
Added variable unwindWarning which can be used to enable an optional warning message if any posted operations contain C-Axis unwind motion.
Added an additional option for Misc. Integer 7 used to determine the C-Axis start position. Operations with (MI7 = 2) will start near C0 including negative positions within its limits. (example: [-2, 2])
Modified the provided control definition to support changes related to Misc. Integers and Arc output.
Changes/Additions for Version 5.0.0
26.5.0.0 - For Mastercam 2026
7/31/25
Added variables TopPlane_C and use_TopPlane_C that can be used to specify a locked or fixed C-Axis position for 2D (3-Axis) operations created in the Top-Plane.
- Fixed operation comments to support multi-line output. Any operations posted with operation comments will now be formatted to include an associated line number.
Added variable spindleConfig can now be used to indicate single-end (ATC) or dual-end (DE) spindles. An additional post question has been added for this variable such that the value of spindleConfig can be set when posting. Files posted for machines with dual-end (DE) spindles will automatically override upper/lower limits for the 5th axis.
Fixed internal logic for 4th/5th Axis Override (enabled with Misc. Values), such that posted files follow the behavior described in the support manual. Any operations posted with 4th/5th Axis Override will now be accompanied by comments indicating the axis and position specified.
Improved variable descriptions found in the .mcpost file to mimic those found in post documentation/support manual.
Modified the default value of defToolLength and its description. For users posting with Length Compensation, the defToolLength or pivot distance will be 12.
Changes/Additions for Version 4.10.1
25.0.4.10 - For Mastercam 2025
7/14/25
Improved error and warning messages displayed while posting. The operation number from the Toolpath Manager will be provided when a fault occurs, in leu of providing its index in posted operations.
- Fixed erroneous C360 to C0 motion following multi-axis linking operations when posted with non-continuous C-Axis. Operations following multi-axis linking now maintain their C position for values of C360 and values within the specified limits. (example: [-2, 362])
6/19/25
Added variable zAxisGTC for the Z-Axis Global Tool Position (Safe tool change position). Previous versions of the post used a fixed position Z0. (relative to machine home). This new variable allows for a machine specific Z-Axis position to be defined.
Added the flag useGTCPos to allow Safe Tool Change Position (GTC) to be disabled. If this value is set to "no$" the GTC positioning will not occur before or after tool changes. As a result, tool changes will occur from the ZTC for posted operations. The user postblocks pCustom_PreTool and pCustom_PostTool may still be used to define positioning before and after a tool change.
Fixed a rare case of AB +/- crossover found in operations posted with non-continuous C.
Changes/Additions for Version 4.9
25.0.4.9 - For Mastercam 2025
24.0.4.9 -For Mastercam 2024
6/04/25
Fixed a minor bug related to calls to pCustom_NewOpStart originally added in Version 4.7. Calls to this custom user postblock should behave as originally described.
Changes/Additions for Version 4.8
25.0.4.8 - For Mastercam 2025
24.0.4.8 -For Mastercam 2024
5/27/25
Added additional sample code to the User Customization section, including 3 new variable initializations used to represent a string, integer, and decimal value.
Added sample format statements fs30/fs31 and format assignments for integer and decimal output respectively. User defined format statements should be limited from fs30 to fs50 to avoid errors when posting.
Added 3 sample formula questions fq30/fq31/fq32 associated with each of the three sample variables. User defined formula questions should be limited fq30 to fq50 to avoid errors when posting.
Added pUser_PostQuestions postblock with sample code that can be used to prompt for user input. The sample code illustrates a set of logical statements that check the values of 3 user variables and asks corresponding post questions. Any post questions called from pUser_PostQuestions will occur after default questions. Updated values can be used in any existing custom postblocks.
Changes/Additions for Version 4.7
25.0.4.7 - For Mastercam 2025
24.0.4.7 -For Mastercam 2024
5/21/25
- Added useCustom_NewOpStart value and pCustom_NewOpStart postblock for user customization. When enabled, pCustom_NewOpStart will be called at the start of every new operation directly after default Operation Start comment and may be used for optional stop (M00/M01) or any other desired function.
- Added functionality for 3D Circle Macros (M922/M923), utilizing canned drill cycles Misc. #1 and Misc. #2. This includes supporting changes to enable drill cycles, updated text descriptions, and variable output options.
- Modified the default value for unwind retract length from 0.5in to 3.0in. This is only applicable to posted files with a non-continuous C-Axis.
Changes/Additions for Version 4.6
25.0.4.6 - For Mastercam 2025
24.0.4.6 -For Mastercam 2024
4/8/25
Added an additional option for useCustom_Footer. Option #2 now allows users to apply the default footer and append the custom footer defined. When enabled, pCustom_Footer will be called after returning the spindle to the park/home position found in the default footer.
Changes/Additions for Version 4.5
25.0.4.5 - For Mastercam 2025
24.0.4.5 -For Mastercam 2024
3/6/25
Fix for index motion in continued 2D operations. With depth cuts and clearance enabled, index motion may not maintain clearance height. Changes to allow clearance and index before continuation and redundant positions added at the start of continued operations. Current behavior maintains separation of index and approach motion for 2D operation and maintains behavior of [Clearance - Only at start and end of operation] and [Depth Cuts – Keep tool down] if enabled.
Changes/Additions for Version 4.4
25.0.4.4 - For Mastercam 2025
24.0.4.4 -For Mastercam 2024
2/27/25
Fix for G25C virtual unwind/reset for machines with a continuous C-Axis. Logic updated to reset Axis-4 between operations if C is outside the range [-360, 360]. Supporting changes were made to maintain negative values for Axis-4 between operations.
Added toolSpindleFormat value to user customization to optionally output tool change (T#) and spindle on macro (M3/M4) on separate lines.
Fix to account for CCW spindle direction (M4) and preventative changes for sequential operations when the same tool changes direction.
Changes/Additions for Version 4.3
25.0.4.3 - For Mastercam 2025
24.0.4.3 -For Mastercam 2024
(Not Released)
Fix for dual table park sequence present when posting with dual-table (shuttle output), additional G27 (cancel axis redirect) added.
Changes/Additions for Version 4.2
25.0.4.2 - For Mastercam 2025
24.0.4.2 -For Mastercam 2024
9/17/24
Fix for 3-Axis Arc/Helix motion with incorrect I/J/K values when the arc is not normal to the tool.
Added supporting changes to determine the plane of arc/helix motion independently from tool orientation. From any major plane arc/helix motion may be output normal to the tool or in any other major plane with the proper I/J/K values.
Added supporting changes to account for I/J/K values if Length Compensation is enabled.
25.0.4.1 - For Mastercam 2025
24.0.4.1 -For Mastercam 2024
(Not Released)
Added a Post Question for ABAxisConfig. Customers machines that do not share the same axis-5 naming convention can post without the need to modify the (.mcpost) file.
Added and updated the default value for tableConfig, such that AFL and comments in posted files will reference table names based on the configuration of axis-5.
Changes/Additions for Version 4.0
25.0.4.0 - For Mastercam 2025
24.0.4.0 -For Mastercam 2024
7/3/24
Fix for 2D toolpaths with “keep tool down” enabled. Top-Plane 3-Axis operations starting with NCI 0-3, the memory stack will be disabled.
Added forced/redundant output for all axes at the start of all continued 3-Axis operations for safety and readability.
* This version includes modifications to the distributed Control Definition (THERMWOOD_5X_2025.mcam-control), Canned Cycles should be disabled by default. *
Changes/Additions for Version 3.8
25.0.3.8 - For Mastercam 2025
24.0.3.8 -For Mastercam 2024
3/26/24
Fix for 3-Axis motion anomaly found in 2D toolpaths in which index motion was performed at federate (G01) and not rapid (G00).
