title: How D-J Engineering Transformed Tooling with LSAM
description: See how they cut lead times from months to weeks with faster, reliable, repeatable results.
image: https://blog.thermwood.com/hubfs/FACEBOOK_THUMBNAIL_D-J-1.png
[![Thermwood](https://blog.thermwood.com/hs-fs/hubfs/THM_LOGO_600_DPI-1.png?width=733&height=100&name=THM_LOGO_600_DPI-1.png)
](http://www.thermwood.com)
- [Learn More About LSAM](https://www.thermwood.com/lsam_home.htm)
- [Why LSAM?](https://blog.thermwood.com/en-us/en-us/why-lsam-blog-00)
- [Request Info on LSAM](https://info.thermwood.com/lsam-email-updates)
## ** How D-J Engineering Transformed Tooling with LSAM **
"LSAM has completely upended what we can do."*
**Tyler Hieber, Engineering Manager, D-J Engineering**
[![LSAM Info Request](https://no-cache.hubspot.com/cta/default/41868/0dcc7f0b-5174-4b32-ac74-748eaeb3d7dd.png)](https://cta-redirect.hubspot.com/cta/redirect/41868/0dcc7f0b-5174-4b32-ac74-748eaeb3d7dd)
##  See how they cut lead times from months to weeks with faster, reliable, repeatable results.
Aerospace manufacturer, [D-J Engineering](https://www.djgrp.com/) uses their [Thermwood LSAM MT 1010 ](https://www.thermwood.com/lsam_home.htm)to produce stretch form blocks, mill fixtures, and complex aerospace tooling in weeks instead of months. The result is:
✅ Faster lead times
✅ Reliable performance
✅ Repeatable results
[LSAM](https://www.thermwood.com/lsam_home.htm) is not just speeding up production, it is transforming the way D-J Engineering approaches tooling and manufacturing.
### More LSAM INFO/Videos
<https://www.thermwood.com/lsam_home.htm>
##### Shaping the Future of Composites Manufacturing
In this in-depth conversation, Dr. Byron Pipes & Dr. Eduardo Barocio of Purdue University explore the groundbreaking collaboration between **Purdue University**, the **CAMS Consortium**, and **Thermwood’s LSAM (Large Scale Additive Manufacturing)** technology. Together, they are helping reshape the landscape of advanced manufacturing.
##### Thermwood Adds a Third Print Option to LSAM
LSAM systems currently can print both horizontal and vertical layers if equipped with the Vertical Layer Print (VLP) option, available on most Thermwood LSAM machines. This new addition adds Angle Layer Printing (ALP) to the VLP option. Angle Layer Printing is the ability to print at a 45 degree angle. **[More Info on Angle Layer Printing here](https://blog.thermwood.com/thermwood-adds-angle-layer-printing-to-its-lsam-large-scale-additive-systems-blog-11-30-21).**
##### Thermwood LSAM 1020 Printing a High Temp Aerospace Tool
See how quickly the versatile Thermwood 𝐋𝐒𝐀𝐌 𝟏𝟎𝟐𝟎 prints a high-temperature aerospace tool for 𝐒𝐓 𝐄𝐧𝐠𝐢𝐧𝐞𝐞𝐫𝐢𝐧𝐠 𝐌𝐑𝐀𝐒 (𝐌𝐑𝐀𝐒), a global leader in manufacturing complex aerostructures, including nacelle systems and specialized airframe components.
##### Thermwood LSAM 1020 Machining a High Temperature Aerospace Tool
See how quickly the versatile Thermwood 𝐋𝐒𝐀𝐌 𝟏𝟎𝟐𝟎 Machining a high-temperature aerospace tool[prints and machines a high-temperature aerospace tool](https://blog.thermwood.com/thermwood-lsam-1020-printing-and-machining-a-high-temp-aerospace-tool-for-st-engineering-mras?utm_campaign=Thermwood%20LSAM%201020%20Printing%20and%20Machining%20a%20High%20Temperature%20Aerospace%20Tool&utm_source=hs_email&utm_medium=email&_hsenc=p2ANqtz-_Af73JijlaDX5MdVHxarjRJqBYuHaVNj4hiPvCl1uVkzspnuuUf20Ck9B56R0st4FehNK-) for 𝐒𝐓 𝐄𝐧𝐠𝐢𝐧𝐞𝐞𝐫𝐢𝐧𝐠 𝐌𝐑𝐀𝐒 (𝐌𝐑𝐀𝐒), a global leader in manufacturing complex aerostructures, including nacelle systems and specialized airframe components.
##### Thermwood LSAM 1020 Printing a project for Naval Surface Warfare Center
Sneak Peak into the printing process of a project for Naval Surface Warfare Center.
##### Thermwood LSAM 5 Axis Trimming Capabilities
Did you know our cutting-edge LSAM systems can be configured with a separate 5-axis trimming head?
Like this LSAM 1020 flagship model, for example. It features a dual-gantry setup where one gantry can print while the other trims simultaneously, streamlining your workflow like never before!
##### Introducing the LSAM Additive Printer
In response to requests for a somewhat smaller, lower cost additive system which still has all the features and print quality of the large flagship LSAM systems, Thermwood has developed and is now offering a line of “print only” machines.
##### Thermwood & General Atomics Save $50K by partnering on Additive Tool
Thermwood recently collaborated with General Atomics to produce a CNC trim tool with a significant cost savings of around $50,000 when compared to traditional methods.
##### Take a Tour of the Thermwood LSAM
LSAM (Large Scale Additive Manufacturing) Product Manager, Scott Vaal explains all the different aspects of the Thermwood LSAM and provides insight into this unique solution for large scale additive manufacturing
##### Thermwood MT VLP Printing High Temp Part
Watch the LSAM MT VLP (Vertical Layer Print) a high temperature part out of Techmer PM 25% carbon fiber filled PSU/PESU blend.
##### LSAM 3D Printed Marine Boat Hull Pattern
3D Printed Marine Boat Hull Pattern made out of Techmer Electrafil© ABS LT1 3DP. The entire print, assembly and trim process required less than ten working days to complete.
##### Al Davis Memorial Torch at Allegiant Stadium in Las Vegas
LSAM owner Dimensional Innovations developed and built the 93-foot tall, 3D-printed commemorative Al Davis Memorial Torch in the new Las Vegas Raiders stadium using their Thermwood LSAM 1020 Large Scale Additive Manufacturing System!
##### Unclassified Submarine Nose 3D Printed for US Navy
This initial validation program was centered on printing an unclassified scale nose of a submarine using Thermwood’s LSAM additive manufacturing system.
##### Why LSAM?
Companies have been choosing Thermwood’s LSAM large scale additive manufacturing systems for their thermoplastic composite large part production. In this video, Scott Vaal, Thermwood’s LSAM Product Manager, addresses the question of “Why LSAM?”
##### LSAM 1020 printing a Multi-Piece Foundry Pattern
The pattern was printed on an LSAM 1020, and machined on a Thermwood 5 Axis Model 90 (because of other projects that were pending on the LSAM).
##### Thermwood and Bell 3D Print Helicopter Blade Mold
A joint venture program between Thermwood and Bell has pushed the limits of 3D printing, resulting in what Thermwood believes is the largest 3D printed autoclave capable tool ever made. This mold, for an 18 1/2 foot long helicopter blade, and is comprised of two halves, which fit together to form the blade.
##### Boeing and Thermwood partner to create large, single-piece tool for the 777X program
Boeing and Thermwood Corporation have employed additive manufacturing technology to produce a large, single-piece tool for the 777X program. The project is demonstrating that additive manufacturing is ready to produce production quality tooling for the aerospace industry.
##### Introducing the LSAM MT
The LSAM MT, offers an all new configuration and significant advantages in certain applications.  It features a single fixed gantry mounted over a moving table. Available with a 10x10 foot table.
### **Request More Information on LSAM**
[![THM_LOGO_300_DPI.fw-1](https://blog.thermwood.com/hs-fs/hubfs/THM_LOGO_300_DPI.fw-1.png?width=600&name=THM_LOGO_300_DPI.fw-1.png)](http://thermwood.com/lsam_home.htm)
[![LSAM_SeriesRV3_2020_mod.fw-2](https://blog.thermwood.com/hs-fs/hubfs/LSAM_SeriesRV3_2020_mod.fw-2.png?width=600&name=LSAM_SeriesRV3_2020_mod.fw-2.png)](http://thermwood.com/lsam_home.htm)
![thermwood_lsam_additive_printer_10_5_small.fw](https://blog.thermwood.com/hs-fs/hubfs/thermwood_lsam_additive_printer_10_5_small.fw.png?width=780&name=thermwood_lsam_additive_printer_10_5_small.fw.png)
![LSAM_15FOOT_MACHINES_ALONE.fw](https://blog.thermwood.com/hs-fs/hubfs/LSAM_15FOOT_MACHINES_ALONE.fw.png?width=600&name=LSAM_15FOOT_MACHINES_ALONE.fw.png)
##### Contact Us:
Contact Us:
**Thermwood Corporation**
904 Buffaloville Road
Dale, Indiana 47523-9057
Sales: 1-800-533-6901
Technical Service: 1-800-221-3865
Thermwood Main Fax: 1-812-937-2956
Thermwood Sales Fax: 1-812-937-7053
Sales Email: [sales@thermwood.com](https://blog.thermwood.com/sales@thermwood.com)
Service Email: service@thermwood.com
Business Hours: 7:00am-4:00pm (M-F)
[![Thermwood](https://blog.thermwood.com/hs-fs/hubfs/THM_LOGO_600_DPI.png?width=600&height=82&name=THM_LOGO_600_DPI.png "Thermwood")](https://info.thermwood.com/)
- [Privacy Policy](http://thermwood.com/privacy_notice.htm)
Copyright © Thermwood Corporation
[**](https://www.facebook.com/thermwood/)[**](https://twitter.com/thermwood)[**](https://www.instagram.com/thermwood/)[**](http://youtube.com/thermwoodcorporation)
![Quantcast](http://pixel.quantserve.com/pixel/p-ef0KmNPVclx2A.gif)
```json
  "@context" : "https://schema.org",
  "@type" : "VideoObject",
  "caption" : {
    "@type" : "MediaObject",
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/195299230554/en.vtt",
    "inLanguage" : "en",
    "name" : "en Captions"
  "contentUrl" : "https://stream.mux.com/p2mGKafNCj01EhL6eCREggcBV6L4uRPDmf01602IJVOADg/capped-1080p.mp4",
  "dateModified" : "2025-09-04T18:48:49.807Z",
  "duration" : "PT8M43.565S",
  "height" : 1080,
  "name" : "Tyler Hieber with D-J Engineering on their Thermwood LSAM MT 1010",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/DJ%20HD%20OUT.mp4/medium.jpg?t=1757011729807",
  "uploadDate" : "2025-08-29T19:09:05.909Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/194145518604/en.vtt",
  "contentUrl" : "https://stream.mux.com/FRrEipPa7Y5lYWx0201Vt79VjBbW00gLDEdA02SV60237jtA/capped-1080p.mp4",
  "dateModified" : "2025-09-04T18:49:04.942Z",
  "duration" : "PT18M31.68S",
  "height" : 1080,
  "name" : "Shaping the Future of Composites Manufacturing - Featuring Dr. Byron Pipes &amp; Dr. Eduardo Barocio of Purdue University",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Purdue%20Lsam%20Interview%20Final_smaller.mp4/medium.jpg?t=1757011744942",
  "uploadDate" : "2025-08-08T15:39:00.413Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/60817386896/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20ALP%20Video.m4v",
  "dateModified" : "2025-09-04T18:23:20.801Z",
  "duration" : "PT1M41.936S",
  "height" : 1080,
  "name" : "LSAM ALP Video",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20ALP%20Video.m4v/medium.jpg?t=1757010200801",
  "uploadDate" : "2021-11-29T21:32:33.047Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/181944664204/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Thermwood%20LSAM%201020%20Printing%20a%20High%20Temperature%20Aerospace%20Tool.mp4",
  "dateModified" : "2025-09-04T18:43:11.732Z",
  "duration" : "PT1M50.653S",
  "height" : 1080,
  "name" : "Thermwood LSAM 1020 Printing a High Temperature Aerospace Tool",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Thermwood%20LSAM%201020%20Printing%20a%20High%20Temperature%20Aerospace%20Tool.mp4/medium.jpg?t=1757011391732",
  "uploadDate" : "2024-10-25T18:52:33.736Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/181948352543/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Thermwood%20LSAM%201020%20Machining%20a%20High%20Temperature%20Aerospace%20Tool.mp4",
  "dateModified" : "2025-09-04T18:43:23.835Z",
  "duration" : "PT4M20.8S",
  "height" : 2160,
  "name" : "Thermwood LSAM 1020 Machining a High Temperature Aerospace Tool",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Thermwood%20LSAM%201020%20Machining%20a%20High%20Temperature%20Aerospace%20Tool.mp4/medium.jpg?t=1757011403835",
  "uploadDate" : "2024-10-25T19:30:52.038Z",
  "width" : 3840
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/172826855566/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/lsam_nswc_6_26_24.mp4",
  "dateModified" : "2025-09-04T18:43:12.327Z",
  "duration" : "PT3M11.034S",
  "height" : 1080,
  "name" : "Sneek Peak: Printing Process on a Thermwood LSAM 1020 for Naval Surface Warfare Center",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/lsam_nswc_6_26_24.mp4/medium.jpg?t=1757011392327",
  "uploadDate" : "2024-07-12T14:21:42.902Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/170430714921/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20trimming%20ABS%20part.mp4",
  "dateModified" : "2025-09-04T18:43:23.754Z",
  "duration" : "PT53.3S",
  "height" : 2160,
  "name" : "LSAM 5 Axis Trimming Capabilities",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20trimming%20ABS%20part.mp4/medium.jpg?t=1757011403754",
  "uploadDate" : "2024-06-14T18:00:32.496Z",
  "width" : 3840
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/50065268868/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20Additive%20Printer_rev_4_7_2_21.m4v",
  "dateModified" : "2025-09-04T18:18:56.005Z",
  "duration" : "PT17M30.25S",
  "height" : 1080,
  "name" : "LSAM Additive Printer_rev_4_7_2_21",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20Additive%20Printer_rev_4_7_2_21.m4v/medium.jpg?t=1757009936005",
  "uploadDate" : "2021-07-02T19:34:49.389Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/35058856509/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/general_atomics_version_5_9_17_20.m4v",
  "dateModified" : "2025-09-04T18:03:43.264Z",
  "description" : "on Additive Tool with Significant Cost Savings",
  "duration" : "PT2M24.019S",
  "height" : 1080,
  "name" : "Thermwood and General Atomics Partner on Additive Tool with Significant Cost Savings",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/general_atomics_version_5_9_17_20.m4v/medium.jpg?t=1757009023264",
  "uploadDate" : "2020-09-17T18:06:20.627Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/35277947500/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Take%20a%20Tour%20of%20the%20Thermwood%20LSAM3.mp4",
  "dateModified" : "2025-09-04T18:03:58.783Z",
  "duration" : "PT10M39.097S",
  "height" : 1080,
  "name" : "Take a Tour of the Thermwood LSAM",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Take%20a%20Tour%20of%20the%20Thermwood%20LSAM3.mp4/medium.jpg?t=1757009038783",
  "uploadDate" : "2020-09-23T13:06:07.354Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/34201912766/zh.vtt",
    "inLanguage" : "zh",
    "name" : "zh Captions"
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20MT%20VLP%20High%20Temp%20Demonstration.m4v",
  "dateModified" : "2025-09-04T18:03:43.035Z",
  "description" : "Thermwood recently demonstrated its VLP (Vertical Layer Printing) capabilities on an LSAM MT 1010.  The part was printed out of Techmer blended 25% carbon filer filled PSU/PESU.  Total print time for the project was 16 hours and 40 minutes, and the final weight of the part was 1,190 lbs.  The final part dimensions were 108.6\" (x) x 33\" (Y) x 45\" (Z).",
  "duration" : "PT3M39.428S",
  "height" : 1080,
  "name" : "LSAM MT VLP High Temp Demonstration",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20MT%20VLP%20High%20Temp%20Demonstration.m4v/medium.jpg?t=1757009023035",
  "uploadDate" : "2020-08-27T18:26:50.956Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/34190693386/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%203D%20Printed%20Marine%20Boat%20Hull%20Pattern.m4v",
  "dateModified" : "2025-09-04T18:03:30.662Z",
  "description" : "3D Printed Marine Boat Hull Pattern made out of Techmer Electrafil© ABS LT1 3DP.  The entire print, assembly and trim process required less than ten working days to complete. After the printed and trimmed tool was coated and finished, a fiberglass mold was produced using the printed pattern. This effort clearly demonstrates the feasibility, practicality, economics and advantages of using additive manufacturing in the production of boat tooling.",
  "duration" : "PT2M54.008S",
  "height" : 720,
  "name" : "LSAM 3D Printed Marine Boat Hull Pattern",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%203D%20Printed%20Marine%20Boat%20Hull%20Pattern.m4v/medium.jpg?t=1757009010662",
  "uploadDate" : "2020-08-27T14:04:23.021Z",
  "width" : 1280
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/60014629529/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Al%20Davis%20Memorial%20Torch%20at%20Allegiant%20Stadium%20in%20Las%20Vegas.mp4",
  "dateModified" : "2025-09-04T18:23:26.505Z",
  "duration" : "PT3M25.636S",
  "height" : 720,
  "name" : "Al Davis Memorial Torch at Allegiant Stadium in Las Vegas",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Al%20Davis%20Memorial%20Torch%20at%20Allegiant%20Stadium%20in%20Las%20Vegas.mp4/medium.jpg?t=1757010206505",
  "uploadDate" : "2021-11-18T15:05:55.819Z",
  "width" : 1280
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/6517680158/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/naval_surface_warfare_thm_lsam_timelapse_video_sub_nosecone_rev2.m4v",
  "dateModified" : "2025-09-04T17:58:21.700Z",
  "duration" : "PT2M4.971S",
  "height" : 1080,
  "name" : "naval_surface_warfare_thm_lsam_timelapse_video_sub_nosecone_rev2",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/naval_surface_warfare_thm_lsam_timelapse_video_sub_nosecone_rev2.m4v/medium.jpg?t=1757008701700",
  "uploadDate" : "2018-11-13T21:04:36.263Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/46924344672/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/why_lsam_version_1_0_rev_6.m4v",
  "dateModified" : "2025-09-04T18:19:05.090Z",
  "description" : "Why LSAM?",
  "duration" : "PT23M15.661S",
  "height" : 1080,
  "name" : "Why LSAM?",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/why_lsam_version_1_0_rev_6.m4v/medium.jpg?t=1757009945090",
  "uploadDate" : "2021-05-11T14:56:45.831Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/34167849820/zh.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%201020%20printing%20a%20Multi-Piece%20Foundry%20Pattern.m4v",
  "dateModified" : "2025-09-04T18:03:15.828Z",
  "description" : "Thermwood recently completed a 3d printed multi-piece foundry pattern.  The pattern was printed on an LSAM 1020, and machined on a Thermwood 5 Axis Model 90 (because of other projects that were pending on the LSAM).\n\nThe pattern was printed out of ABS (20% carbon fiber fill).  Print time for the project was 6 hours and 40 minutes, and the trim time was a little over 47 hours with multiple fixture setups.\nMore info on LSAM:  http://bit.ly/2KheM0r",
  "duration" : "PT3M25.164S",
  "height" : 1080,
  "name" : "LSAM 1020 printing a Multi-Piece Foundry Pattern",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%201020%20printing%20a%20Multi-Piece%20Foundry%20Pattern.m4v/medium.jpg?t=1757008995828",
  "uploadDate" : "2020-08-27T14:11:58.681Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/34195366680/en.vtt",
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/bell_blade_mold_preview_video_1_29_19.m4v",
  "dateModified" : "2025-09-04T18:03:23.145Z",
  "duration" : "PT2M13.676S",
  "height" : 1080,
  "name" : "bell_blade_mold_preview_video_1_29_19",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/bell_blade_mold_preview_video_1_29_19.m4v/medium.jpg?t=1757009003145",
  "uploadDate" : "2020-08-27T15:34:02.026Z",
  "width" : 1920
```json
  "caption" : {
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/6483160319/ja.vtt",
    "inLanguage" : "ja",
    "name" : "ja Captions"
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Boeing_VLP_Time_Lapse_rev_3_no_logo.m4v",
  "dateModified" : "2025-09-04T17:58:11.655Z",
  "duration" : "PT1M56.054S",
  "height" : 1080,
  "name" : "Boeing_VLP_Time_Lapse_rev_3_no_logo",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/Boeing_VLP_Time_Lapse_rev_3_no_logo.m4v/medium.jpg?t=1757008691655",
  "uploadDate" : "2018-11-08T20:34:27.718Z",
  "width" : 1920
```json
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/LSAM%20MT%20Introduction.m4v",
  "dateModified" : "2022-06-01T05:48:22.360Z",
  "description" : "The LSAM MT (moving table) features a single fixed gantry mounted over a moving table.  Available with a 10x10 foot table.  The LSAM MT can also be configured as a \"Print Only\" machine.  It can also be equipped with Thermwood's patented Vertical Layer Printing technology.  This means that it can make parts up to 10'x10' by 5 foot high using traditional Horizontal Layer Printing, or 5'x10' by 10 foot high using Vertical Layer Printing.",
  "duration" : "PT1M37S",
  "height" : 1080,
  "name" : "LSAM MT Introduction",
  "thumbnailUrl" : "https://api-na1.hubapi.com/filemanager/api/v3/files/thumbnail-redirect/34190815582?portalId=41868&size=medium",
  "uploadDate" : "2020-08-27T14:20:42.280Z",
  "width" : 1920
