Featuring Dr. Byron Pipes & Dr. Eduardo Barocio of Purdue University
In this in-depth conversation, they explore the groundbreaking collaboration between Purdue University, the CAMS Consortium, and Thermwood’s LSAM (Large Scale Additive Manufacturing) technology. Together, they are helping reshape the landscape of advanced manufacturing.
From advancing large-scale 3D printing to developing simulation-driven software tools, this partnership is accelerating innovation and transforming how research translates into real-world industrial solutions.
Watch the interview to hear their insights on:
- Why digital simulation is the key to unlocking the full potential of additive manufacturing
- How LSAM technology helps bridge the gap between research and production
- The impact of collaborative research on the future of composite materials for aerospace, automotive, and defense
More LSAM INFO/Videos
Cut Lead Times from months to weeks with faster, reliable, repeatable results
Aerospace manufacturer, D-J Engineering uses their Thermwood LSAM MT to produce stretch form blocks, mill fixtures, and complex aerospace tooling in weeks instead of months. The result is:
✅ Faster lead times
✅ Reliable performance
✅ Repeatable results
Thermwood Adds a Third Print Option to LSAM
LSAM systems currently can print both horizontal and vertical layers if equipped with the Vertical Layer Print (VLP) option, available on most Thermwood LSAM machines. This new addition adds Angle Layer Printing (ALP) to the VLP option. Angle Layer Printing is the ability to print at a 45 degree angle. More Info on Angle Layer Printing here.
Thermwood LSAM 1020 Printing a High Temp Aerospace Tool
See how quickly the versatile Thermwood 𝐋𝐒𝐀𝐌 𝟏𝟎𝟐𝟎 prints a high-temperature aerospace tool for 𝐒𝐓 𝐄𝐧𝐠𝐢𝐧𝐞𝐞𝐫𝐢𝐧𝐠 𝐌𝐑𝐀𝐒 (𝐌𝐑𝐀𝐒), a global leader in manufacturing complex aerostructures, including nacelle systems and specialized airframe components.
Thermwood LSAM 1020 Machining a High Temperature Aerospace Tool
See how quickly the versatile Thermwood 𝐋𝐒𝐀𝐌 𝟏𝟎𝟐𝟎 Machining a high-temperature aerospace toolprints and machines a high-temperature aerospace tool for 𝐒𝐓 𝐄𝐧𝐠𝐢𝐧𝐞𝐞𝐫𝐢𝐧𝐠 𝐌𝐑𝐀𝐒 (𝐌𝐑𝐀𝐒), a global leader in manufacturing complex aerostructures, including nacelle systems and specialized airframe components.
Thermwood LSAM 1020 Printing a project for Naval Surface Warfare Center
Sneak Peak into the printing process of a project for Naval Surface Warfare Center.
Thermwood LSAM 5 Axis Trimming Capabilities
Did you know our cutting-edge LSAM systems can be configured with a separate 5-axis trimming head?
Like this LSAM 1020 flagship model, for example. It features a dual-gantry setup where one gantry can print while the other trims simultaneously, streamlining your workflow like never before!
Introducing the LSAM Additive Printer
In response to requests for a somewhat smaller, lower cost additive system which still has all the features and print quality of the large flagship LSAM systems, Thermwood has developed and is now offering a line of “print only” machines.
Thermwood & General Atomics Save $50K by partnering on Additive Tool
Thermwood recently collaborated with General Atomics to produce a CNC trim tool with a significant cost savings of around $50,000 when compared to traditional methods.
Take a Tour of the Thermwood LSAM
LSAM (Large Scale Additive Manufacturing) Product Manager, Scott Vaal explains all the different aspects of the Thermwood LSAM and provides insight into this unique solution for large scale additive manufacturing
Thermwood MT VLP Printing High Temp Part
Watch the LSAM MT VLP (Vertical Layer Print) a high temperature part out of Techmer PM 25% carbon fiber filled PSU/PESU blend.
LSAM 3D Printed Marine Boat Hull Pattern
3D Printed Marine Boat Hull Pattern made out of Techmer Electrafil© ABS LT1 3DP. The entire print, assembly and trim process required less than ten working days to complete.
Al Davis Memorial Torch at Allegiant Stadium in Las Vegas
LSAM owner Dimensional Innovations developed and built the 93-foot tall, 3D-printed commemorative Al Davis Memorial Torch in the new Las Vegas Raiders stadium using their Thermwood LSAM 1020 Large Scale Additive Manufacturing System!
Unclassified Submarine Nose 3D Printed for US Navy
This initial validation program was centered on printing an unclassified scale nose of a submarine using Thermwood’s LSAM additive manufacturing system.
Why LSAM?
Companies have been choosing Thermwood’s LSAM large scale additive manufacturing systems for their thermoplastic composite large part production. In this video, Scott Vaal, Thermwood’s LSAM Product Manager, addresses the question of “Why LSAM?”
LSAM 1020 printing a Multi-Piece Foundry Pattern
The pattern was printed on an LSAM 1020, and machined on a Thermwood 5 Axis Model 90 (because of other projects that were pending on the LSAM).
Thermwood and Bell 3D Print Helicopter Blade Mold
A joint venture program between Thermwood and Bell has pushed the limits of 3D printing, resulting in what Thermwood believes is the largest 3D printed autoclave capable tool ever made. This mold, for an 18 1/2 foot long helicopter blade, and is comprised of two halves, which fit together to form the blade.
Boeing and Thermwood partner to create large, single-piece tool for the 777X program
Boeing and Thermwood Corporation have employed additive manufacturing technology to produce a large, single-piece tool for the 777X program. The project is demonstrating that additive manufacturing is ready to produce production quality tooling for the aerospace industry.
Introducing the LSAM MT
The LSAM MT, offers an all new configuration and significant advantages in certain applications. It features a single fixed gantry mounted over a moving table. Available with a 10x10 foot table.
