DXF Buddy is Now Available from CNC Automation
Posted by Jason Susnjara on Mon, Apr 27, 2009
Tags: Thermwood, CNC Routers, software, CNC Automation, Special, Cad, Layered DXF, control nesting, super controller, Gen2, DXF Buddy
 Are you working with Layered DXF files and Control Nesting? Do you run into issues with any of the following?
  • OUTLINE layer depths not matching material thicknesses at the machine...
  • Parts to be machined in "grained" material being drawn in the wrong orientation...
  • You need a left-hand AND right-hand gable but only have the left-hand DXF...
  • The DADO layer is not being recognized because if was incorrectly labeled "DAOD"...
  • You need to flip the back operations to the front and then front operations to the back...
  • No CAD system or CAD operator out at the machine...
DXF Buddy
is here! This small and easy utility will run at the machine and help you rectify all of the issues listed above and then some.
DXF Buddy
is available in two versions - Standard and Pro. The Standard version incorporates a DXF Part Viewer and the ability to manipulate many aspects of the Layered DXF file without the need of accessing a CAD system. The Pro version has all the capabilities of the Standard module and also provide a DXF List Management module that allows you to create a list of DXF parts, set quantities, easily assign materials, mirror/rotate or "pair" individual parts and annotate each entry with a JOB/ASSEMBLY and CAB/SUB-ASSEMBLY designation. The lists DXF Buddy Pro "builds" can then be loaded into Control Nesting in one easy step.
Both versions of DXF Buddy 1.0 have an introductory price of less than $100 CAD!
NOTES:
  • Each license can be installed and run on only one (1) computer. (Software registers to the computer.)
  • All support is done via a email (dxf.buddy@cncautomation.com) or on the special forum on the
B2B-Online-Community. No phone support is provided.
Visit the SOFTWARE section of the CNC Automation web store - http://store.cncautomation.com/
