Take a Tour of the Thermwood Cut Ready Cut Center
With this second Info Spot video, Jody Wilmes (Cut Ready Product Manager), takes you on a walk-around tour of the Cut Ready Cut Center to help you learn more about the different aspects of this powerful machine.
Jody provides an in-depth look and explanation of the features of the Cut Center and how every component has been designed to help make it easy to operate and maintain.
Helpful Insight When Choosing an Automated Solution
Jody Wilmes (Cut Ready Product Manager), helps you understand the differences between the Cut Center and a regular CNC machine.
Jody provides an in-depth look at what it takes to successfully operate each machine, and lists some of the additional expenses and things to consider when shopping for an automated solution for your application.
How to Design a Cabinet and Add it to the Job in Cut Ready
Learn how quick and easy it is to design and customize a cabinet in Cut Ready. Just select what you want and Cut Ready will make it!
Cut out a Cabinet Job
In this video, we will machine the cabinet job that we created last time. See how the software tells you what to do, even if you run into a problem...like breaking a tool.
Please click here to check out our other Cut Ready Info Spot Videos
What Some of Our Cut Center Owners Are Saying...
