Learn How Easy it is to Machine a Cabinet in Cut Ready
Cut Ready’s Bath cabinets now have the option to combine into one larger combination cabinet. We successfully introduced this feature several months ago for kitchens and are expanding it to include bath cabinets too. As customers have found, there are many benefits with combination cabinets over the traditional single cabinet layouts.
Some Benefits:
- Less material & expendables (labels, tooling, etc.)
- Less parts to sort, assemble, edge band or potentially damage
- Increased cabinet space
- Better grain matching
- Easier to level/straighten one cabinet vs. multiple cabinets
- Reduced labor and overhead
- Increased profits
To Access this Feature:
As you select options to make your bath cabinets, you will eventually be asked this question:
Note: This is an unusually large update and will require time to download. Continue using the system as you normally would while it is downloading.
Shutting the machine down will not cause any harm. The system will continue downloading when it is turned back on.
