The 2015 WMS Show (November 5th-7th) promises to be an exciting opportunity to visit Toronto and see the very latest technology from Thermwood!
Like the award winning Thermwood Cut Center (make virtually anything a cabinet shop would want to make - with no programming), as well as the AutoProcessor 5'x10' (a high-speed, automatic load/unload, heavy-duty CNC routing system for nested based feed through machining).
Please come and visit us at CNC Automation booth #2013. Click this link (use promo code CNCAUT15) to obtain passes to the show on behalf of CNC Automation (exclusive Canadian Thermwood dealer).
Cut Center
With the award-winning Thermwood Cut Center, there are no computers or design software. Everything is already in the machine. There is no programming. The cut center doesn’t need a computer to tell it how to move because it already knows how to make cabinets. Just tell it what you want to make, and it does it - it is that simple!
Operate as a CNC Router with CNC AccessIf you want to operate the Cut Center as a CNC Router, you can. With CNC Access, you can operate the Cut Center as a CNC router in the traditional manner, running programs generated with virtually any CNC software. Plus, (using eCabinet Systems software and following specific design protocols), you can custom design products and add them to the Cut Center libraries and then those items can be machined by the Cut Center with no further programming.
AutoProcessor
The AutoProcessor 5'x10' is a high-speed, automatic load/unload, heavy-duty CNC routing system for nested based feed through machining. It is used in nested based production of cabinets, closets and custom furniture.
