Thermwood and Bell 3D Print Helicopter Blade Mold
Posted by Duane Marrett on Thu, Feb 07, 2019
Tags: Thermwood, Thermwood LSAM, LSAM, 3D Print, 3D printing, Additive Manufacturing, Additive, Announcements, Bell, Bell Helicopter, Bell Flight, Helicopter
A joint venture program between Thermwood and Bell has pushed the limits of 3D printing, resulting in what Thermwood believes is the largest 3D printed autoclave capable tool ever made.
The first half of an 18 foot helicopter blade mold that was 3D Printed on a Thermwood LSAM in just over 3 hours.
The first half of an 18 foot helicopter blade mold that was 3D Printed in just over 3 hours
A common limiting factor within aerospace development programs is expensive, long-lead time tooling.  Bell, not being satisfied abiding by the industry norms, decided to reach out to Thermwood to help solve this challenge.
Glenn Isbell quote regarding Thermwood's LSAM
Video
The Challenge
Shortly after initial conversations with Bell, the Thermwood team offered an opportunity of a partnership centering around the capabilities of their new 60mm melt core technology.  The original challenge for quickly and affordably manufacturing large bond tooling seemed closer to reality than ever before.
Bell responded to this opportunity in kind by providing Thermwood a model of a closed cavity blade mold measuring approximately 20 feet long, 14 inches wide and 17 inches high.
The basic tooling requirements were as follows:
  • Must to be printed in one continuous run for vacuum integrity
  • Surface finish must be 32 RMS or better
  • Tooling must be able to withstand 90 psi at 360°F.
  • Tight tolerances and features were also required to ensure proper mating of the two blade mold halves.
The Process
Upon receiving the model and requirements, the Thermwood team sprang into action. Utilizing their new 60mm melt core technology, they began to print the tool using TechmerPM’s 25% Carbon Fiber reinforced PESU (Polyethersulfone) in one continuous run. Working closely with Thermwood, Techmer has formulated this material specifically for LSAM additive printing.
The printable material has a Glass Transition Temperature of over 400°F and can easily survive common aerospace component cure cycles of up to 360°F, at 90psi. The combination of Techmer's new materials and Thermwood's printing technology, resulted in a print time of one tool half in just 3 hours 8 minutes and an “as printed” weight of 542 pounds.
Thermwood technicians claim the Techmer PESU material prints as easily as ABS, although at a much higher temperature, allowing quality autoclave-capable molds to be made from the high temperature polymer.
Thermwood LSAM 3D Printing an 18 ft helicopter blade mold
This extraordinary achievement was made possible by a new, larger melt core recently installed on Thermwood’s LSAM system at its Development/Demonstration Lab in Southern Indiana. The standard LSAM machine print head housing can be equipped with different capacity melt cores, each offering different minimum and maximum throughputs.
Continuous Cooling Print Process
With Thermwood’s room temperature “Continuous Cooling” print process, the cycle time for each layer is determined solely by how long it takes a particular printed polymer to cool to the proper temperature to accept the next layer.
Only by printing at the proper temperature can you achieve a totally fused, void-free printed structure that will maintain vacuum in an autoclave without a coating. The print head output determines how much material can be printed during the time it takes for the layer to cool. Bigger print heads mean larger parts, not necessarily faster layer to layer print time.
LSAM Print 3D software infared camera view.
Thermographic view of the part being printed
The new 60mm melt core has a measured maximum output of 480 to 570 pounds per hour depending on the polymer being printed and can print over 100 feet of typical print bead (.830” x .200”) per minute. This high print rate, even when processing high temperature material, allows the print bead to be oriented along the length of the tool. This is desirable for Bell, who manufactures large composite parts, because thermal expansion is significantly lower in that direction, minimizing expansion and contraction of the tool with temperature changes.
Internal Printed Support Structure
Another interesting feature of this tool is that the internal printed structure supports the mold without actually contacting or touching the back side of the mold cavity. This means air can flow freely under the entire formed part in the autoclave, making the part curing process easier and more consistent. The ability to incorporate a complex internal design, such as this, is another major advantage of using additive manufacturing for this type of tooling.
Internal 3D Printed support structure in a 18 foot hellicopter blade mold on a Thermwood LSAM
3D printed internal support structures
Thermwood’s LSAM Print 3D slicing software specifically supports programming of involved internal structures such as these.
Internal support structure shown on LSAM Print 3D software.
Internal support structures in  LSAM Print 3D slicing software
Bell Investigates Multiple Manufacturing Processes
Bell is continuing to investigate integrated technologies that support multiple manufacturing processes and tools.  The LSAM is capable of supporting printing processes as well as trim and drill processes to meet aerospace specifications.  Once printed, the team began to machine the bond tool half by utilizing the other aspect of the LSAM system.  The total machining time of the lower blade mold half was 40 hours.
James Cordell quote regarding Thermwood's LSAM
The completed bond tool was able to maintain Bell’s vacuum standards required for autoclave processing right from the machine, without the need for a seal coating
Part maintaining vacuum during extended testing
The part steadily holding vacuum during testing
Next Steps
The Thermwood team will print the second half of the blade mold, with the intention of having Bell cure a full molded blade within the final additively-manufactured bond tool, another first.  Further testing will be completed by both Thermwood and Bell teams on PESU printed molds, to continue innovating in this space.
Final Thoughts
Ken Susnjara Quote on Bell
Thermwood believes recent LSAM technology advances such as Vertical Layer Printing and Changeable Melt Cores (coupled with polymers specially tailored for LSAM processing), are opening exciting new possibilities for additive production of even larger and more technically complex components.
More Information on LSAM
LSAM is based on exciting new technology developed from an entirely new direction.
Much of the technology used in Thermwood's LSAM machines and print process is completely new. Thermwood has already received numerous patents on these revolutionary developments and many more are in the works.
LSAM is the Leader in Large Scale Additive Sales
In the last year, Thermwood's LSAM additive manufacturing systems were the clear market leaders in the sale of large scale 3D printing systems for thermoplastic composite materials, selling virtually all systems in the US during the year.
LSAM is truly state-of-the-art in the exciting new world of large scale additive manufacturing.
The Secret to LSAM Print Quality...A Different Process
Examples of large parts easily printed on Thermwood's LSAM
