Thermwood Cut Ready 43 Video - Machining a Door and Matching Drawer Front Using Diamond Tooling
Posted by Duane Marrett on Fri, Jun 07, 2019
Tags: Thermwood, Cut Ready, Cut Center, cabinets, Video, doors, No Programming, Cut Ready 43, Artie
The video below shows the powerful Cut Ready 43 machining a door and matching drawer front in MDF using diamond tooling.
MDF Doors on the Cut Ready 43 machined with diamond tooling
Cut Ready 43 Door and Drawer Front Video
More Info on the Cut Ready 43 with Artie Inside
The Cut Ready 43 shown above is equipped with a 5 by 8 table, a 21-position tool changer and a high flow vacuum hold-down system (additional table sizes and options are available).
The Cut Ready 43 is intended to bring the magic of Artie to a lower priced system. It features a full-sized vacuum table and, just like its big brother, doesn’t require a CNC programmer. Just like a Cut Center, it can help you quickly and easily create most products a cabinet shop would want to make without a CNC programmer (only operational training is required).
Since this is a CNC router at its core, you are free to program and operate it as a normal CNC router if you want, but the magic of Artie makes the Cut Ready 43 a whole new exciting experience!
For More Info on the Cut Ready 43, please click here.
Learn More about Artie
Learn more about Artie and how he helps you operate the Cut Ready 43
Cut Ready doesn't need a programmer because there is already one inside the control. We call him "Artie".
Despite the cute name, Artie is actually a cutting edge, artificial intelligence engine inside the Cut Ready control.
He is the first A.I. dedicated to making your manufacturing life easier to handle.  While he is a CNC programmer and designer at heart, he also watches over your shoulder to make sure everything goes smoothly and efficiently.
You tell him what you want and he creates a program to make it. Be it cabinets, doors, moldings or furniture, Artie will program it for you!
These are not pre-programmed libraries. No part programs exist in the control until Artie creates them.  He is already capable of programming tens of millions of unique products and is constantly learning how to make and do more and more new things. Artie is easy enough that virtually anyone can work with him with little or no training. For more on Artie, click here.
