Below is a new video showing the redesigned Thermwood FrameBuilder 53 5'x10' CNC router in action.
The machine in the video features the following options:
- Automatic load/unload system with 6,000 lb lift table and unload sorting table
- Dual 18HP (3,000-18,000 RPM) HSD spindles with programmable head spacing
- Two optional electric drills
Video
About the FrameBuilder 53
The Thermwood FrameBuilder 53 series is a heavy duty, high-performance three-axis CNC machining center. It is specifically developed for the machining of upholstery frames and other sheet goods that require rollers on each side of the spindle to hold various materials typically not held by vacuum while machining. The redesigned FB53 is now equipped with rack and pinion for both the X and Y Axes, bigger drives, and a redesigned gantry that is stiffer while allowing more options. These changes represent over 110% increase in speed from the original (various table sizes up to 20' are available). |
| FrameBuilder 53 5×10 Shown w/optional dual spindles | |
| FrameBuilder 53 5×10 Shown w/optional dual spindles and 6,000 lb load table | |
Features of the FrameBuilder 53:
Dimensional Drawings (featuring optional dual spindle and load/unload): |
