Tags:
                    Additive,
                    LSAM,
                    Additive Manufacturing,
                    VLP,
                    High Temperature,
                    ALP,
                    HLP,
                    LFAM,
                    LSAM1540
Another LSAM 1540 is in the works — what could YOU build with this additive titan?
Thermwood is building another powerhouse in our LSAM (Large Scale Additive Manufacturing) line — a high-performance 1540 model designed to produce massive, high-precision components.
This system is packed with advanced capabilities:
Print Gantry:
 Patented 60mm melt core
 Prints up to 500 lbs per hour
 Handles both low- and high-temp thermoplastics
 Operates at temperatures up to 450°C
 60" vertical stroke for tall part production
 Self-contained fume and smoke collection system
5-Axis Trim Gantry:
 72" vertical stroke
 362° horizontal and 270° vertical rotation
 Multi-axis feed speeds up to 2,100 inches per minute
 High-performance 24HP, 24,000 RPM variable-speed router
 12-position automatic tool changer located under the gantry
 Automatic lubrication system for reduced maintenance
 High-tolerance automatic tool length sensor
 Superior chip collection system
 Can print and trim at the same time — no part relocation needed
Three Print Orientations:
 Vertical Layer Printing (VLP): Print full-length parts in a single section
 Standard Horizontal Printing
 Angle Layer Printing (ALP): Print at a 45° angle for complex geometry
This LSAM 1540 is built for speed, scale, and flexibility — and it's almost ready. Stay tuned for updates as it nears completion!
Learn More About LSAM
LSAM 1540 Shown
