Can I Afford a Thermwood Cut Center?
Posted by Duane Marrett on Tue, Nov 22, 2016
Tags: Thermwood, Cut Ready, Cut Center, 2016, Affordable, Purchase, Why Purchase a Thermwood
“I’ll buy a CNC router as soon as I can afford it”.  Is this something you’ve said to yourself time and time again over the years?  Surveys indicate that 50% to 70% of cabinet shops say this, depending on which survey you read. A CNC router is automation, it is productivity and it is on every cabinetmakers short list of things they would really, really like to have. So exactly when can you afford a CNC router?
The simple answer is that you can afford it when it will make you more than it costs.  Taking a look at the Thermwood Cut Center, for instance, the Cut Center may have a slightly higher than average purchase price, but the immediate benefits and ability to get into production quickly can outweigh any initial costs.
The Cut Center is Different in a Good Way
The Thermwood Cut Center is Different in a Good WayThe Cut Center is not like any regular CNC router you may be familiar with.  It doesn’t require you to learn complex programming to operate, and is so user-friendly that it walks you through every step of the process when making cabinets, closets, furniture, doors, drawers and much more.  You simply tell the machine what you want to make via an easy to use touch screen interface, and it does it.  No programming is required.
"No Programming" is a Huge Factor
Thermwood Cut Center - No Programming!
That little bit about “no programming” is huge factor – no matter how great of a deal you get on the purchase of a CNC router, it will still need to be programmed.  This means that you either need to learn to program yourself or you’ll need to hire a CNC programmer.
A typical CNC programmer will cost you more each month than the payment on a Thermwood Cut Center.  And every few years, that programmer will most likely cost more money, while the payments on a Cut Center will go away once the machine is paid off.
How About Programming it Myself?
No programming necessary with the Thermwood Cut Center
Programming it yourself is possible, but it isn’t simple.  CNC routers require a constant stream of programs to run. Solving problems (like damaged or scrapped parts or defects in material) means even more CNC programs. Programming custom cabinets on a CNC router is a full time job….good thing you have nothing else to do!
No Software Required
And don’t forget about the software to run the CNC router. Cheap cabinet software is limited and difficult. It will most likely take more time to learn and operate, which means more money. Really good software can cost as much, or more than a cheap CNC router, and then you still need to learn to use it.
Save By Using Scrap Material
Save money by using your scrap material with the Thermwood Cut CenterAnother consideration is scrap material. You will most likely have one or more partial sheets left from each job. Regardless of what they tell you, it is so difficult, complex and expensive to add this to new jobs that virtually everyone just throws it away. With the Cut Center, you just scan the label on any extra material lying around and it is added to the job, automatically. This can mean a lot of money saved at the end of the year.
Get Into Production Quickly
Get into production quickly with the Thermwood Cut Center
With the typical Thermwood Cut Center installation, you can be in full production is a little as about half a day.  A regular CNC router can take as much as six months to get to that point.  A half a day or half a year?  In business, time is money, and there is serious cost associated with that half a year.
Enhancing Employee Productivity
Enhance employee productivity with the Thermwood Cut Center
A new CNC router can sometimes be seen by employees as intimidating or threatening when it is installed into a shop.  Your workers may either be worried that their jobs could be affected by this dazzling new piece of equipment, or that they will be required to learn an entirely new programming language or operating procedure.  With the Thermwood Cut Center, there is no programming knowledge necessary.  Basically anyone can walk up to the machine, pick out part(s), select their desired quantities/sizes and make it.  The Cut Center is designed to be as simple as possible to operate, and to help shops and employees be more productive and efficient.
Another Way to Make Money with a Thermwood Cut Center
List your business for free on the Thermwood Production Sharing MapFinally, there is Production Sharing. This is a program where you sell production time on your machine by making parts for other shops that don’t have a Cut Center or CNC router. Thermwood provides an area on our web site where you can advertise your services (there is no cost for this), and you work directly with the other shops to set up your jobs.  Thermwood receives no money for these transactions.
More about the Thermwood Cut Center:
Operate as a Cut Center with No Programming
Operate the Thermwood Cut Center as a CNC Router or a Cut Center
Thermwood Cut Center Product SelectionWith the award-winning Thermwood Cut Center, there are no computers or design software. Everything is already in the machine. There is no programming. The cut center doesn’t need a computer to tell it how to move because it already knows how to make cabinets. Just tell it what you want to make, and it does it - it is that simple!
Operate as a CNC Router
Also, you can operate the system as a CNC router in the traditional manner, running programs generated with virtually any CNC software. Thermwood has created a simple way to switch between operating as a CNC router and operating as a Cut Center to assure that all machine parameters are properly reset and that the standard Cut Center tooling is properly installed, checked and ready to run.
Operate as a Cut Center or as a CNC Router - the best of both worlds!
What our Cut Center Customers Think...
Jody Wilmes and the guys at Original Woodworking with their new Thermwood Cut Center
Jody Wilmes and the Donovan Mumma of Byrne Custom Woodworking and their new Thermwood Cut Center
Jody Wilmes and the guys at Arkansas Wood Doors and their new Thermwood Cut Center
Jody Wilmes and the guys at Bednark Studio and their new Thermwood Cut Center
Upcoming Cut Center Feature Video - MDF Doors Using Profile Tooling with Corner Cleanup
Posted by Duane Marrett on Fri, Nov 04, 2016
Tags: Thermwood, Cut Ready, Cut Center, Video, 2016, MDF doors, Updated Features
ThThermwood Cut Center - MDF Doors made with standard profile tooling with corner cleanupermwood's Award Winning Cut Ready Cut Center is an alternative to traditional CNC routers for making custom cabinets and furniture with NO programming.
With the Cut Center, you have two choices in how you can operate. You can use it as an easy-to-operate Cut Center (just tell it what you want to make and it does it), or you can use it as a traditional CNC router with CNC Access.
Upcoming Feature Preview:
We are constantly adding new features and capabilities to the powerful Cut Center.  Please click below to see a video preview of the newest - the ability to quickly and easily machine MDF doors using standard profile tooling with corner cleanup. Just select the door(s) you would like to make, select the profile, input the size(s) and the Cut Center makes it.
What Our Customers Are Saying
About The Cut Ready Cut Center
Operate as a Cut Center with NO Programming or as a Traditional CNC Router, running programs generated with virtually any CNC software.
Get Hands-On Experience with the Thermwood Cut Center at IWF 2016!
Posted by Duane Marrett on Thu, Aug 18, 2016
Tags: Thermwood, Cut Ready, Cut Center, Video, 2016, FrameBuilder 48, Model 45, IWF, Trade Shows
The 2016 IWF Show (August 24th-27th) promises to be an exciting opportunity to visit Atlanta and see the very latest technology from Thermwood (booth #6513)!
Like the award-winning Cut Center (make virtually anything a cabinet shop would want to make - with no programming), the all-new Framebuilder 48 (for nested-based upholstered frames featuring an auto load/unload system and built-in chip collection hood) and the heavy-duty Model 45 utilizing pods and aggregate tooling (machining solid wood parts).
Try out the award-winning Cut Center for yourself at IWF 2016!
The award-winning Thermwood Cut Center (which can be operated as an easy-to-use Cut Center with no programming, or as a traditional CNC router - running programs generated with virtually any CNC software) will be in action during IWF 2016.
You'll have the opportunity to see just how easy it is to run this powerful machine.  Just tell it what you want, and it makes it...it is that easy!  We'll be demonstrating live during the show, and you can be part of it by helping to operate the cut center.  Please visit our booth (#6513) and speak to a Thermwood representative to get your hands on this exciting machine!
FrameBuilder 48 - Auto Load/Unload System and Chip Collection HoodThermwood FrameBuilder 48
Thermwood is also proud to demonstrate our all-new FrameBuilder 48 (4'x8' table) CNC router equipped with optional dual 18 HP Spindles and dual electric drills for nested based upholstered frame production.
Featuring an auto load/unload system to automate the process of feeding the machine sheet material and automatically off-loading the parts upon completion. The system is also equipped with a built-in chip collection hood that cleans the table as it executes the automatic load/unload cycle.  The FrameBuilder 48 will be in action at IWF 2016 in booth #6513.
Solid Wood Machining on the Thermwood Model 45Thermwood CabinetShop 45
 We will also be demonstrating solid wood door machining utilizing pods and aggregate tooling on the Thermwood Model 45
The heavy-duty Model 45 is designed for a variety of functions including the machining of rotary operations when equipped with our optional C-Axis. This expands the capability of this already useful machine to include volutes, carvings, chair parts, stair components and much more.
Model 45 with Pod System Machining Poplar Hardwood Door:
Thermwood Model 45 Machining a Poplar Hardwood Door
See at IWF 2016:
All three of these machines will be on display and cutting live at IWF 2016 (August 24th-27th) in Thermwood booth #6513 at the Georgia World Congress Center - Atlanta, GA.  Make plans now to visit us and see this exciting new technology in person!
More Info
For more info on the Thermwood Cut Center, please visit cutready.com.  For more info on the FrameBuilder 48 or Model 45 CNC routers, please visit us at thermwood.com.
Thermwood Cut Center Virtual Demonstration
Posted by Duane Marrett on Wed, Jul 20, 2016
Tags: Thermwood, Cut Ready, Cut Center, Video, 2016, Testimonials
Thermwood's Award Winning Cut Ready Cut Center is an all-new alternative to traditional CNC routers for making custom cabinets and furniture with NO programming.
Try out the Thermwood Cut Center at IWF 2016!
You can see the Cut Center in action at the 2016 IWF show in Atlanta (August 24th-27th) Booth #6513, and you'll also have the opportunity to see just how easy it is to run this new machine yourself.
Please click below to see a virtual demonstration of the Thermwood Cut Center machining a mitered box.
Thermwood Heavy-Duty High-Performance Model 45 Videos
Posted by Duane Marrett on Tue, Apr 26, 2016
Tags: Thermwood, High Performance, Model 45, Video, 2016, Heavy Duty
dual_spindle_m45_lg.jpgThe Thermwood Multi-Purpose 45 is a heavy-duty, high-performance three axis CNC router available in either single or dual spindles with optional rotary axis used in the machining of cabinets, solid wood, millwork, phenolic, display fixtures and much more.
Features of the Model 45:
  • Fixed table sizes from 5'x5' to 7'x12'
  • Optional Rotary Axis
  • Moving Gantry
  • Single or Dual 12P HSD Spindle (3,000-24,000RPM)
  • 4 Position Bar Style Automatic Tool Changer
  • Optional Single or Dual 18HP HSD Spindle Available
  • Optional 5-Position At-the-Head AutomaticTool Changer Available
  • Optional Nemi Pod System Available
  • Automatic Lubrication (optional)
  • QCore SuperControl
  • Siemens Intelligent Servo Drives Throughout
  • 3D Laser Compensated Axis Alignment
  • Automatic Tool Length Sensor (optional)
  • Free Lifetime Phone/Forum Support
What Our Customers Are Saying About the Thermwood Cut Center
Posted by Duane Marrett on Tue, Apr 19, 2016
Here we present videos featuring three new Thermwood Cut Center owners and their impressions of the machine and its capabilities.
Take a listen to Michael Bednark of Bednark Inc. in Brooklyn, NY, John Allan of Arkansas Wood Doors in Pottsville, AR and Donovan Mumma of Byrne Custom Woodworking in Lenexa, KS as they discuss their new Cut Centers and what the machine is going to do for each business.
2016 Thermwood Dealer Conference
Posted by Duane Marrett on Wed, Apr 13, 2016
Tags: Thermwood, Announcements, Dealer Conference, Tech Con, CAM Automatizacion, AAI, Carbon Studio, skf enterprises, 2016
We recently held our 2016 Dealer Conference at our headquarters in Dale, IN. The purpose of this annual event is to get all of our domestic and international dealers together in round-table informative sessions to discuss sales strategies and also to present the exciting changes and new products we plan to release in the next year.
Of course, the conference isn't all work and no play!  It also gives everyone a chance to socialize and catch up on news, as well as the opportunity to award our top sellers special prizes at the awards dinner.
This year, our top dealership was Automation Associates, Inc.  Second and third places went to Tech Con and S.K.F. Enterprises.  The award for the dealership with the Most Improved Sales for 2015 went to Cam Automatizacion.  The award for top International Sales went to Carbon Studio/AP Group, LLC out of Russia.  Congratulations, guys!
1st Place AAI
Pictured above are: (l-r) Jason Susnjara (VP Marketing for Thermwood), Mark Drone (Automation Associates, Inc) and Dennis Palmer (VP Sales for Thermwood).
2nd Place Tech Con
Pictured above are: (l-r) Jason Susnjara (VP Marketing for Thermwood), Glenn Suss (Tech Con), Robert Vollmer (Tech Con) and Dennis Palmer (VP Sales for Thermwood).
3rd Place S.K.F. Enterprises
Pictured above (l-r) are: Jason Susnjara (VP Marketing for Thermwood), Brent East (Accepting for Dave White of S.K.F. Enterprises) and Dennis Palmer (VP Sales for Thermwood).
Most Improved - Cam Automatizacion
Pictured above are: (l-r) Jason Susnjara (VP Marketing for Thermwood), Pablo Macias (Cam Automatizacion) and Dennis Palmer (VP Sales for Thermwood).
Top International Sales - Carbon Studio
Pictured above are: (l-r) Jason Susnjara (VP Marketing for Thermwood), Ekaterina Malykhina (Carbon Studio/AP Group, LLC) and Dennis Palmer (VP Sales for Thermwood).
Cut Center Demonstration
Thermwood personnel, domestic and international dealers attend a Cut Center demonstration during the 2016 Dealer Conference.
2016 Dealer Conference Training
Thermwood personnel, domestic and international dealers during the 2016 Dealer Conference.
