Update adds Significant New Features to Thermwood’s Cut Center
Posted by Duane Marrett on Tue, Jan 06, 2015
Tags: Cut Ready, Cut Center, Furniture, Custom, EZ Office
Thermwood released the first update for its Cut Ready - Cut Centers today, adding new product libraries, plus additions to existing libraries as well as some all new cutting routines. In addition, you can now have your products (which may not be part of the standard product offering) custom added to your Cut Center!  This is a serious update incorporating some major technical advances
The Cut Center, introduced at IWF in Atlanta, allows shops to manufacture a large variety of cabinets, and related products with no computers, software or CNC programming. It’s easy and can be run by existing folks without specialized training. This update increases the number and variety of products Cut Centers can make, plus adds new capabilities not previously found on this type of machine
EZ Office
Cut Center EZ OfficeIt adds a line of office furniture, called “EZ Office” suitable for a small business or home office. The entire line is made from a single material, either 3/4 inch or 19mm thick sheet stock. Pieces are assembled using lock joints, which combine mortise and tenon slots with cam-lock fasteners. This is a superior joint resulting in high quality solid construction. Each design includes step by step assembly instructions, suitable for a consumer, so these items could be made from pre-finished material and sold unassembled
Hidden Bed
The second product addition is a Hidden-Bed, which is a large desk that turns into a twin bed. The unique feature of this design is that the desk top remains parallel to the ground as the bed is pulled down so it is not necessary to clear it off to use the bed
The hidden-bed integrates smoothly in both size and design with tall closet cabinets already in the Cut Centers
New "Cuts" Capabilities
We have also added three fundamentally new “Cuts” capabilities. These cutting features introduce an all new way to work with an automated machine… something that has not been done before (this video shows this… it’s worth watching)
Full Thickness Backs Added for Frameless Cabinets
The frameless base cabinet designs in Thermwood’s Cut Center currently have a quarter inch slide-in back, either with or without nailers. Although this works for most in the US, we’ve received requests from Canadian shops for a full thickness, slide-in back option for frameless base cabinets. Reacting to those requests, full thickness backs have been added to frameless base cabinets in the latest Cut Center update
Add Your Products to the Cut Center with "Special Products"
And finally, we have developed a program for those who want to make things not already in the Cut Center. How do you get “No Programming” and the simple, intuitive operation of a Cut Center for your special products? With our new “Special Products” program the answer is simple, we add them for you
Definitions for your unique products are custom developed and installed in your Cut Center. These are not just CNC programs. Definitions teach your machine to make your products in all their variations, all their sizes, from all the materials you use. If your product requires special fixtures or tooling, we will develop and supply them also. This is a complete, ready-to-run solution
Run your products by simply selecting what you want, right at the machine. You can use material of varying thickness and/or adjust product size and features, again, right at the machine. The machine adjusts for all of this with no separate computer, no software and no programming. This is by far the simplest, easiest way to make things. This program is not restricted to cabinets and furniture. It will work for any product that can be manufacturered on a router
You can add additional products at any time and can have existing product definitions modified. We stand ready to manage your product offering so you don’t have to
With the “Special Products” addition, you still have all the features and product capabilities of the standard Cut Center, with your unique products as an added benefit
Continuous Free Updates
This new Cut Center update, which adds valuable new features and exciting new products, is available to all Cut Center users as a free download, right through their machine. Thermwood expects to continually update both product offering and system capabilities and, as they are developed, these advances will be offered free to existing Cut Center users
