LSAM 5 Axis Trimming Capabilities
๐ Did you know our cutting-edge LSAM systems can be configured with a separate 5-axis trimming head?
๐ Like this LSAM 1020 flagship model, for example. It features a dual-gantry setup where one gantry can print while the other trims simultaneously, streamlining your workflow like never before!
Hereโs a quick rundown of our innovative models:
- ๐๐๐๐ ๐๐๐๐: A closed high-wall system with doors on each end, featuring a single control with both print and trim heads on one moving gantry. Efficient and compact!
- ๐๐๐๐ ๐๐๐๐/๐๐๐๐/๐๐๐๐: These models also feature a closed high-wall
configuration with doors on each end, equipped with dual controls and dual gantries for separate print and trim operations. Perfect for maximizing productivity! - ๐๐๐๐ ๐๐: Designed with an open configuration, it has a single fixed gantry over a moving table, integrating print and trim functions seamlessly.
- ๐๐๐๐ ๐๐ ๐๐/๐๐๐: These systems offer an open configuration, with optional enclosures available. They focus on printing only, with a fixed gantry over a moving table, ideal for specialized tasks.
We offer the broadest range of LFAM systems in the industry, to help you find the perfect solution for your needs and budget. But LSAM systems are more than just 3D printers - they're real production systems, capable of producing industrial fixtures, molds (including high temp), tooling, foundry patterns, prototypes and end products from a wide variety of both low and high temp materials.
๐ ๐ณ๐ฒ๐ ๐๐ฆ๐๐ ๐ฎ๐ฑ๐๐ฎ๐ป๐๐ฎ๐ด๐ฒ๐:
โข LSAM systems offer three printing orientations - HLP (Horizontal Layer Printing), VLP (Vertical Layer Printing), allowing parts to be printed that are as long as the machine table and ALP (Angle Layer Printing), the ability to print at a 45 degree angle.
โข With the fastest print heads in the industry, our LSAM systems can print at speeds from up to 200lbs per hours to over 500 lbs per hour.
โข Choose from Print-only or Print-and-Trim combinations with table sizes ranging from 5โx5โ to 15โx40โ and beyond.
โข Save both time and money over traditional methods - case study here: https://bit.ly/3zWoWjk
๐ฆ๐ฒ๐ฒ ๐๐ ๐น๐ถ๐๐ฒ:
We will next be printing LIVE at IMTS 2024 in Chicago, IL (booth #433103) starting on September 9th with an LSAM AP 510 - visit us to learn more about LSAM, or you can always contact us directly to arrange a personal demonstration at our corporate headquarters.
Learn More About LSAM:
