title: Thermwood Unveils a New Additive Way to Make Metal Molds
description: Thermwood Unveils a New Additive Way to Make Metal Molds
image: https://blog.thermwood.com/hubfs/metal_mold_image_large-1.png
[![Thermwood Corporation Blog](https://blog.thermwood.com/hs-fs/file-1534153785-png/images/Logo.png "Thermwood Corporation Blog")](http://www.thermwood.com/)
## [Thermwood Unveils a New Additive Way to Make Metal Molds](https://blog.thermwood.com/thermwood-unveils-a-new-additive-way-to-make-metal-molds-blog-10-23-23)
Posted by [Duane Marrett](https://blog.thermwood.com/author/duane-marrett) on Wed, Oct 25, 2023
- [Tweet](https://twitter.com/share)
 Tags: [plastics](https://blog.thermwood.com/topic/plastics), [Announcements](https://blog.thermwood.com/topic/announcements), [molds](https://blog.thermwood.com/topic/molds), [thermoforming](https://blog.thermwood.com/topic/thermoforming), [Additive Manufacturing](https://blog.thermwood.com/topic/additive-manufacturing), [CLA](https://blog.thermwood.com/topic/cla), [injection molding](https://blog.thermwood.com/topic/injection-molding), [metal molds](https://blog.thermwood.com/topic/metal-molds), [blow molding](https://blog.thermwood.com/topic/blow-molding), [Cut Layer Additive](https://blog.thermwood.com/topic/cut-layer-additive)
Molds, for plastics processes, such as thermoforming, blow molding, rotational molding and reaction injection molding are commonly made of aluminum. Often, they are large.
Thermwood has developed a simplified, low cost way of making these large molds, using its new Cut Layer Additive process.
![metal_mold_image_large-1](https://blog.thermwood.com/hs-fs/hubfs/metal_mold_image_large-1.png?width=600&height=330&name=metal_mold_image_large-1.png)
### **How Does This Work?**
[**Cut Layer Additive**](https://blog.thermwood.com/en-us/en-us/en-us/cut-layer-additive) works by laminating layers, cut from thick sheets of material, such as aluminum, to create a structure. In addition to building highly efficient structures, the process offers unique capabilities that make it ideal for large plastic molds.
The most important element of a mold is the mold face, essentially the cavity that defines the size and shape of the part. It’s the one thing you absolutely have to have.
Depending on the process, other functions may also be needed, such as vacuum, venting and/or temperature control. Adding these functions usually increases complexity and cost, sometimes significantly.
Thermwood’s new approach incorporates these functions in a mold face that is only a couple inches thick. So, the entire mold, including all required functions, is just the mold face.
It’s simple and less expensive. Cut Layer Additive makes it possible.  In this process, the mold face is built using machined aluminum layers, stacked and permanently attached. Since, prior to assembly, each layer is machined individually in a nest, it is possible to include holes or slots so that, when assembled, they match up, creating internal channels or chambers. These void areas in the mold are then accessed by boring holes from underneath into the opening.
### **Design Flexibility is Incredible**
A channel with an access hole on each end can be used to circulate temperature-controlled liquid, to control mold temperature.
An internal chamber can be also be used for vacuum. Small holes are drilled into the chamber, as is normally done with thermoforming molds. Vacuum applied to the chamber then forms the part.
Thin slots can be machined between layers to provide vents, should they be needed for certain processes.
Design flexibility is incredible.
In this way, all required functions can be included in a relatively thin mold face.
For mounting, selected mold layers are extended downward to create standoffs supports.
This means large molds can now be produced at surprisingly low cost.  This new approach also supports some advanced features.
![Inner views of layers of the mold with holes and slots in place](https://blog.thermwood.com/hs-fs/hubfs/cl1-1.jpg?width=600&height=404&name=cl1-1.jpg)
![Inner views of layers of the mold with holes and slots in place](https://blog.thermwood.com/hs-fs/hubfs/cl2-1.jpg?width=600&height=400&name=cl2-1.jpg)
Because you can create a multitude of channels or chambers inside the mold face, you can easily do things that are not normally possible. For example, you can circulate liquid at different temperatures through different parts of the mold, or you can create vacuum chambers under different areas of the mold and regulate the flow and timing of vacuum to those areas to aid in forming difficult parts.
There are few, if any, restrictions as to the size or geometry of molds that can be produced using this approach.
Although the basic idea is quite simple, there are a lot of details that must come together to make it all work. Programing all these details using traditional CAD would be difficult at best. The effort would likely make the whole approach impractical.
With Cut Layer Additive, the basic mold doesn’t require programming, at least in the usual sense.
Machine Intelligence in the Cut Layer Additive machine actually knows how to make these kinds of molds, so all you need to do is tell it what you want.
This is done in two steps, **show it the shape** and **tell it how you want it made**.
![Just show it the shape and tell it how you want it made.](https://blog.thermwood.com/hs-fs/hubfs/m2-1.jpg?width=600&height=308&name=m2-1.jpg)
The basic shape of the part is all CLA needs
### **CLA just needs a CAD file of the basic shape**
You show it the shape by sending it a CAD file. Not a detail file, just the basic shape you want. Don’t worry about the inside just yet.
In telling it how you want it made, you need to tell it the material you want to use, how thick you want the face, where you want channels, where you want standoffs, and any other details of what you want.
This is actually a lot easier than it sounds. You simply answer questions about how you want it made. The system guides you and makes the entire process rather easy. This part can often be done in less than five minutes.
![CLA can add in holes and slots to each layer to create channels and chambers](https://blog.thermwood.com/hs-fs/hubfs/m1-1.jpg?width=600&height=364&name=m1-1.jpg)
To make molds, Thermwood has added the ability to add holes and slots to each layer to create channels and chambers. New features, while you are defining the part, make this rather easy to do. It does take a bit more effort than just making a cut layer part, but overall, it’s straightforward and the results are stunning.
Truly sophisticated molds are now possible at low cost, with zone temperature control, zone vacuum and more. Cut Layer Additive does it using a tiny fraction of the time it would otherwise take.
It makes the whole thing practical.
![CLA can quickly create the mold with holes and slots that couldn't be made any other way. ](https://blog.thermwood.com/hs-fs/hubfs/cl3-1.jpg?width=600&height=388&name=cl3-1.jpg)
### **Attend CAMX 2023 ****FREE and see CLA for yourself**
CLA will be on display at CAMX 2023 Oct 31st-Nov 2nd in Atlanta, GA!  Visit Thermwood Booth #FF18 to see molds and tools produced on CLA, experience live demonstrations of the software and speak to our representatives to help answer your questions on this exciting new addition to the world of additive manufacturing!
Use the code **119734** to register and attend CAMX 2023 **Free **from Thermwood at the link below:
[https://www.xpressreg.net/register/camx1123/start.asp](https://www.xpressreg.net/register/camx1123/start.asp)
[![CAMX 2023](https://blog.thermwood.com/hs-fs/hubfs/CAMX_2023_Logo_Dates-1.png?width=650&height=251&name=CAMX_2023_Logo_Dates-1.png)](https://www.xpressreg.net/register/camx1123/start.asp)
### Subscribe to Email Updates
### Follow Thermwood!
<http://www.youtube.com/user/thermwoodcnc><http://www.linkedin.com/companies/thermwood-corporation?trk=copro_tab><http://pinterest.com/thermwood/><https://www.facebook.com/114494315256386><https://twitter.com/thermwood>
### Request More Info
### Browse by Tag
- [20-20 (4)](https://blog.thermwood.com/topic/20-20)
- [2013 (1)](https://blog.thermwood.com/topic/2013)
- [2014 (2)](https://blog.thermwood.com/topic/2014)
- [2015 (1)](https://blog.thermwood.com/topic/2015)
- [2016 (7)](https://blog.thermwood.com/topic/2016)
- [2017 (3)](https://blog.thermwood.com/topic/2017)
- [2018 (3)](https://blog.thermwood.com/topic/2018)
- [2019 (2)](https://blog.thermwood.com/topic/2019)
- [2020 (2)](https://blog.thermwood.com/topic/2020)
- [2021 (2)](https://blog.thermwood.com/topic/2021)
- [2022 (4)](https://blog.thermwood.com/topic/2022)
- [2023 (1)](https://blog.thermwood.com/topic/2023)
- [2024 (8)](https://blog.thermwood.com/topic/2024)
- [2025 (2)](https://blog.thermwood.com/topic/2025)
- [2026 (2)](https://blog.thermwood.com/topic/2026)
- [3 Axis (69)](https://blog.thermwood.com/topic/3-axis)
- [3-D volumetric compensation (2)](https://blog.thermwood.com/topic/3-d-volumetric-compensation)
- [3D laser (2)](https://blog.thermwood.com/topic/3d-laser)
- [3D Print (26)](https://blog.thermwood.com/topic/3d-print)
- [3D printing (37)](https://blog.thermwood.com/topic/3d-printing)
- [3Dprinting (2)](https://blog.thermwood.com/topic/3dprinting)
- [4 Axis (1)](https://blog.thermwood.com/topic/4-axis)
- [43 (10)](https://blog.thermwood.com/topic/43)
- [5 Axis (44)](https://blog.thermwood.com/topic/5-axis)
- [5 axis plastics (2)](https://blog.thermwood.com/topic/5-axis-plastics)
- [67 (1)](https://blog.thermwood.com/topic/67)
- [777x (1)](https://blog.thermwood.com/topic/777x)
- [AAI (9)](https://blog.thermwood.com/topic/aai)
- [About (1)](https://blog.thermwood.com/topic/about)
- [Additive (44)](https://blog.thermwood.com/topic/additive)
- [Additive Manufacturing (35)](https://blog.thermwood.com/topic/additive-manufacturing)
- [Additive Manufacturing Guide (1)](https://blog.thermwood.com/topic/additive-manufacturing-guide)
- [Additive tooling (1)](https://blog.thermwood.com/topic/additive-tooling)
- [Advanced Support (3)](https://blog.thermwood.com/topic/advanced-support)
- [Advertisement (5)](https://blog.thermwood.com/topic/advertisement)
- [AeroDef (1)](https://blog.thermwood.com/topic/aerodef)
- [aerospace (12)](https://blog.thermwood.com/topic/aerospace)
- [Affordable (6)](https://blog.thermwood.com/topic/affordable)
- [Agreement (1)](https://blog.thermwood.com/topic/agreement)
- [AIL (1)](https://blog.thermwood.com/topic/ail)
- [Air Force (1)](https://blog.thermwood.com/topic/air-force)
- [Air Force Research Laboratory (1)](https://blog.thermwood.com/topic/air-force-research-laboratory)
- [Airtech (5)](https://blog.thermwood.com/topic/airtech)
- [Al Davis Torch (1)](https://blog.thermwood.com/topic/al-davis-torch)
- [alerts (1)](https://blog.thermwood.com/topic/alerts)
- [ALP (3)](https://blog.thermwood.com/topic/alp)
- [Alpha Woodworks (1)](https://blog.thermwood.com/topic/alpha-woodworks)
- [Alphacam (1)](https://blog.thermwood.com/topic/alphacam)
- [aluminum (10)](https://blog.thermwood.com/topic/aluminum)
- [Announcements (198)](https://blog.thermwood.com/topic/announcements)
- [AP 21 (1)](https://blog.thermwood.com/topic/ap-21)
- [app (1)](https://blog.thermwood.com/topic/app)
- [architectural (1)](https://blog.thermwood.com/topic/architectural)
- [Arkansas Wood Doors (4)](https://blog.thermwood.com/topic/arkansas-wood-doors)
- [artcam (2)](https://blog.thermwood.com/topic/artcam)
- [Artie (11)](https://blog.thermwood.com/topic/artie)
- [Ascent Aerospace (2)](https://blog.thermwood.com/topic/ascent-aerospace)
- [Assembly Marks (5)](https://blog.thermwood.com/topic/assembly-marks)
- [Assistance (1)](https://blog.thermwood.com/topic/assistance)
- [Atlanta (1)](https://blog.thermwood.com/topic/atlanta)
- [AUM Wood Products (1)](https://blog.thermwood.com/topic/aum-wood-products)
- [Auto Labeling (4)](https://blog.thermwood.com/topic/auto-labeling)
- [Auto Load (4)](https://blog.thermwood.com/topic/auto-load)
- [Auto Unload (5)](https://blog.thermwood.com/topic/auto-unload)
- [automotive (1)](https://blog.thermwood.com/topic/automotive)
- [AutoProcessor (4)](https://blog.thermwood.com/topic/autoprocessor)
- [AutoProcessor 43 (3)](https://blog.thermwood.com/topic/autoprocessor-43)
- [AWFS (16)](https://blog.thermwood.com/topic/awfs)
- [back side (1)](https://blog.thermwood.com/topic/back-side)
- [ball state (1)](https://blog.thermwood.com/topic/ball-state)
- [Balusters (1)](https://blog.thermwood.com/topic/balusters)
- [Barb Dado (3)](https://blog.thermwood.com/topic/barb-dado)
- [Bass Pro (1)](https://blog.thermwood.com/topic/bass-pro)
- [Bath Cabinets (3)](https://blog.thermwood.com/topic/bath-cabinets)
- [Bead Board (1)](https://blog.thermwood.com/topic/bead-board)
- [Bednark Studio (2)](https://blog.thermwood.com/topic/bednark-studio)
- [Bell (1)](https://blog.thermwood.com/topic/bell)
- [Bell Flight (1)](https://blog.thermwood.com/topic/bell-flight)
- [Bell Helicopter (1)](https://blog.thermwood.com/topic/bell-helicopter)
- [Blog (1)](https://blog.thermwood.com/topic/blog)
- [blow molding (1)](https://blog.thermwood.com/topic/blow-molding)
- [Boat Hull (2)](https://blog.thermwood.com/topic/boat-hull)
- [BobCAD-CAM (1)](https://blog.thermwood.com/topic/bobcad-cam)
- [Boeing (6)](https://blog.thermwood.com/topic/boeing)
- [Boeing Auburn (1)](https://blog.thermwood.com/topic/boeing-auburn)
- [Book (1)](https://blog.thermwood.com/topic/book)
- [Boy Scout (1)](https://blog.thermwood.com/topic/boy-scout)
- [Brace Feature (1)](https://blog.thermwood.com/topic/brace-feature)
- [Brent East (1)](https://blog.thermwood.com/topic/brent-east)
- [broken tool recovery (1)](https://blog.thermwood.com/topic/broken-tool-recovery)
- [Byrne Custom Woodworking (1)](https://blog.thermwood.com/topic/byrne-custom-woodworking)
- [Cabinet (25)](https://blog.thermwood.com/topic/cabinet)
- [Cabinet Doors, (1)](https://blog.thermwood.com/topic/cabinet-doors)
- [Cabinet Vision (1)](https://blog.thermwood.com/topic/cabinet-vision)
- [Cabinetmaker (1)](https://blog.thermwood.com/topic/cabinetmaker)
- [CabinetPro (1)](https://blog.thermwood.com/topic/cabinetpro)
- [cabinets (31)](https://blog.thermwood.com/topic/cabinets)
- [CabinetShop (14)](https://blog.thermwood.com/topic/cabinetshop)
- [CabinetShop 43 (4)](https://blog.thermwood.com/topic/cabinetshop-43)
- [CabinetShop 43 Nested Based Work Cell (1)](https://blog.thermwood.com/topic/cabinetshop-43-nested-based-work-cell)
- [CabinetShop 45 (1)](https://blog.thermwood.com/topic/cabinetshop-45)
- [CabinetWare (1)](https://blog.thermwood.com/topic/cabinetware)
- [Cad (3)](https://blog.thermwood.com/topic/cad)
- [CAM Automatizacion (4)](https://blog.thermwood.com/topic/cam-automatizacion)
- [Camera (1)](https://blog.thermwood.com/topic/camera)
- [CAMX (3)](https://blog.thermwood.com/topic/camx)
- [Canada (6)](https://blog.thermwood.com/topic/canada)
- [Carbon Studio (2)](https://blog.thermwood.com/topic/carbon-studio)
- [carving (2)](https://blog.thermwood.com/topic/carving)
- [Casual Country Furniture (1)](https://blog.thermwood.com/topic/casual-country-furniture)
- [CGTech (1)](https://blog.thermwood.com/topic/cgtech)
- [Challengers Award (1)](https://blog.thermwood.com/topic/challengers-award)
- [Charlotte (1)](https://blog.thermwood.com/topic/charlotte)
- [Cheap (1)](https://blog.thermwood.com/topic/cheap)
- [chipload calculator (1)](https://blog.thermwood.com/topic/chipload-calculator)
- [Christmas Party (5)](https://blog.thermwood.com/topic/christmas-party)
- [CLA (6)](https://blog.thermwood.com/topic/cla)
- [classic dash (1)](https://blog.thermwood.com/topic/classic-dash)
- [Closet (9)](https://blog.thermwood.com/topic/closet)
- [closets (8)](https://blog.thermwood.com/topic/closets)
- [CNC (75)](https://blog.thermwood.com/topic/cnc)
- [CNC Access (4)](https://blog.thermwood.com/topic/cnc-access)
- [CNC Automation (16)](https://blog.thermwood.com/topic/cnc-automation)
- [cnc innovator (1)](https://blog.thermwood.com/topic/cnc-innovator)
- [CNC Machine (4)](https://blog.thermwood.com/topic/cnc-machine)
- [CNC Mobile App (6)](https://blog.thermwood.com/topic/cnc-mobile-app)
- [CNC output (3)](https://blog.thermwood.com/topic/cnc-output)
- [CNC Router (87)](https://blog.thermwood.com/topic/cnc-router)
- [CNC Routers (76)](https://blog.thermwood.com/topic/cnc-routers)
- [CNC Solutions (2)](https://blog.thermwood.com/topic/cnc-solutions)
- [Collaboration (1)](https://blog.thermwood.com/topic/collaboration)
- [Color (1)](https://blog.thermwood.com/topic/color)
- [Color Coded Labels (1)](https://blog.thermwood.com/topic/color-coded-labels)
- [Combination Cabinets (7)](https://blog.thermwood.com/topic/combination-cabinets)
- [Coming Soon (1)](https://blog.thermwood.com/topic/coming-soon)
- [comparison (1)](https://blog.thermwood.com/topic/comparison)
- [Composite Tooling (2)](https://blog.thermwood.com/topic/composite-tooling)
- [Composites (16)](https://blog.thermwood.com/topic/composites)
- [Compression (1)](https://blog.thermwood.com/topic/compression)
- [Compression Wheel (2)](https://blog.thermwood.com/topic/compression-wheel)
- [Concrete (1)](https://blog.thermwood.com/topic/concrete)
- [Contemporary Floating Bedroom (1)](https://blog.thermwood.com/topic/contemporary-floating-bedroom)
- [Contemporary Wave Bedroom Suite (1)](https://blog.thermwood.com/topic/contemporary-wave-bedroom-suite)
- [Continuous C-Axis Rotation (4)](https://blog.thermwood.com/topic/continuous-c-axis-rotation)
- [control nesting (7)](https://blog.thermwood.com/topic/control-nesting)
- [Convert (1)](https://blog.thermwood.com/topic/convert)
- [cooperative (2)](https://blog.thermwood.com/topic/cooperative)
- [Copper (1)](https://blog.thermwood.com/topic/copper)
- [corner rounding (1)](https://blog.thermwood.com/topic/corner-rounding)
- [Cost (7)](https://blog.thermwood.com/topic/cost)
- [Covid-19 (3)](https://blog.thermwood.com/topic/covid-19)
- [Credit (1)](https://blog.thermwood.com/topic/credit)
- [Culture (1)](https://blog.thermwood.com/topic/culture)
- [Custom (3)](https://blog.thermwood.com/topic/custom)
- [Custom Cuts (1)](https://blog.thermwood.com/topic/custom-cuts)
- [Customer (9)](https://blog.thermwood.com/topic/customer)
- [Customer Lounge (1)](https://blog.thermwood.com/topic/customer-lounge)
- [Cut Center (92)](https://blog.thermwood.com/topic/cut-center)
- [Cut Center Impressions (5)](https://blog.thermwood.com/topic/cut-center-impressions)
- [Cut Center Updates (25)](https://blog.thermwood.com/topic/cut-center-updates)
- [Cut Layer Additive (2)](https://blog.thermwood.com/topic/cut-layer-additive)
- [Cut Ready (78)](https://blog.thermwood.com/topic/cut-ready)
- [Cut Ready 43 (8)](https://blog.thermwood.com/topic/cut-ready-43)
- [CutReady (1)](https://blog.thermwood.com/topic/cutready)
- [dash panels (1)](https://blog.thermwood.com/topic/dash-panels)
- [Dealer Conference (12)](https://blog.thermwood.com/topic/dealer-conference)
- [defense (1)](https://blog.thermwood.com/topic/defense)
- [Demonstrations (17)](https://blog.thermwood.com/topic/demonstrations)
- [Dennis Blackburn (1)](https://blog.thermwood.com/topic/dennis-blackburn)
- [Dennis Englert (1)](https://blog.thermwood.com/topic/dennis-englert)
- [Desks (1)](https://blog.thermwood.com/topic/desks)
- [Diamond Tooling, (1)](https://blog.thermwood.com/topic/diamond-tooling)
- [Dimensional Innovations (2)](https://blog.thermwood.com/topic/dimensional-innovations)
- [Discount (2)](https://blog.thermwood.com/topic/discount)
- [Discovery Education (1)](https://blog.thermwood.com/topic/discovery-education)
- [Display Fixtures (1)](https://blog.thermwood.com/topic/display-fixtures)
- [doors (8)](https://blog.thermwood.com/topic/doors)
- [Double Mattress (1)](https://blog.thermwood.com/topic/double-mattress)
- [Dovetail Drawerbox (1)](https://blog.thermwood.com/topic/dovetail-drawerbox)
- [drawer boxes (2)](https://blog.thermwood.com/topic/drawer-boxes)
- [drawers (1)](https://blog.thermwood.com/topic/drawers)
- [drawing (1)](https://blog.thermwood.com/topic/drawing)
- [Dual Spindle (1)](https://blog.thermwood.com/topic/dual-spindle)
- [Durham (1)](https://blog.thermwood.com/topic/durham)
- [DXF Buddy (1)](https://blog.thermwood.com/topic/dxf-buddy)
- [Easy (6)](https://blog.thermwood.com/topic/easy)
- [Easy CNC (8)](https://blog.thermwood.com/topic/easy-cnc)
- [eCabinet Systems (22)](https://blog.thermwood.com/topic/ecabinet-systems)
- [Edge Banding Adjustment (1)](https://blog.thermwood.com/topic/edge-banding-adjustment)
- [edgebander (8)](https://blog.thermwood.com/topic/edgebander)
- [edgebanding (8)](https://blog.thermwood.com/topic/edgebanding)
- [education (6)](https://blog.thermwood.com/topic/education)
- [electronic brochure (1)](https://blog.thermwood.com/topic/electronic-brochure)
- [Employees (11)](https://blog.thermwood.com/topic/employees)
- [Employment (1)](https://blog.thermwood.com/topic/employment)
- [energy digital (1)](https://blog.thermwood.com/topic/energy-digital)
- [Entrepreneurial (1)](https://blog.thermwood.com/topic/entrepreneurial)
- [Equipment Hub (1)](https://blog.thermwood.com/topic/equipment-hub)
- [Examples (1)](https://blog.thermwood.com/topic/examples)
- [EZ Office (2)](https://blog.thermwood.com/topic/ez-office)
- [Face Frame (1)](https://blog.thermwood.com/topic/face-frame)
- [Face Shield (1)](https://blog.thermwood.com/topic/face-shield)
- [Facebook Live (1)](https://blog.thermwood.com/topic/facebook-live)
- [factory (1)](https://blog.thermwood.com/topic/factory)
- [Family (1)](https://blog.thermwood.com/topic/family)
- [Fancy Ridge Wood Products (1)](https://blog.thermwood.com/topic/fancy-ridge-wood-products)
- [FARO (1)](https://blog.thermwood.com/topic/faro)
- [FDM (1)](https://blog.thermwood.com/topic/fdm)
- [Features (5)](https://blog.thermwood.com/topic/features)
- [Field Service Technician (1)](https://blog.thermwood.com/topic/field-service-technician)
- [Fixture (1)](https://blog.thermwood.com/topic/fixture)
- [FLC 2012 BIKE MS (1)](https://blog.thermwood.com/topic/flc-2012-bike-ms)
- [Fleet Readiness Center (1)](https://blog.thermwood.com/topic/fleet-readiness-center)
- [flycut (2)](https://blog.thermwood.com/topic/flycut)
- [Flycut Routine (1)](https://blog.thermwood.com/topic/flycut-routine)
- [Foam (1)](https://blog.thermwood.com/topic/foam)
- [Forintek (1)](https://blog.thermwood.com/topic/forintek)
- [Formnext (1)](https://blog.thermwood.com/topic/formnext)
- [Foundry (1)](https://blog.thermwood.com/topic/foundry)
- [FrameBuilder 48 (1)](https://blog.thermwood.com/topic/framebuilder-48)
- [FrameBuilder 53 (1)](https://blog.thermwood.com/topic/framebuilder-53)
- [Frameless (1)](https://blog.thermwood.com/topic/frameless)
- [Fravol (2)](https://blog.thermwood.com/topic/fravol)
- [FRC East (1)](https://blog.thermwood.com/topic/frc-east)
- [Free (9)](https://blog.thermwood.com/topic/free)
- [Furniture (23)](https://blog.thermwood.com/topic/furniture)
- [Gen2 (3)](https://blog.thermwood.com/topic/gen2)
- [General Atomics (2)](https://blog.thermwood.com/topic/general-atomics)
- [Giben (1)](https://blog.thermwood.com/topic/giben)
- [Google Earth (1)](https://blog.thermwood.com/topic/google-earth)
- [Grain Matching (1)](https://blog.thermwood.com/topic/grain-matching)
- [Green (2)](https://blog.thermwood.com/topic/green)
- [GSA (1)](https://blog.thermwood.com/topic/gsa)
- [guide (2)](https://blog.thermwood.com/topic/guide)
- [Habitat for Humanity (3)](https://blog.thermwood.com/topic/habitat-for-humanity)
- [Half Century Award (1)](https://blog.thermwood.com/topic/half-century-award)
- [handbook (1)](https://blog.thermwood.com/topic/handbook)
- [Happy Holiday (1)](https://blog.thermwood.com/topic/happy-holiday)
- [hardwood doors (1)](https://blog.thermwood.com/topic/hardwood-doors)
- [Heavy Duty (4)](https://blog.thermwood.com/topic/heavy-duty)
- [Helicopter (1)](https://blog.thermwood.com/topic/helicopter)
- [High Performance (11)](https://blog.thermwood.com/topic/high-performance)
- [High Temperature (9)](https://blog.thermwood.com/topic/high-temperature)
- [High Temperature Material (2)](https://blog.thermwood.com/topic/high-temperature-material)
- [High Tolerance Tool Length Sensor (1)](https://blog.thermwood.com/topic/high-tolerance-tool-length-sensor)
- [Hightech Cabinets (1)](https://blog.thermwood.com/topic/hightech-cabinets)
- [History (2)](https://blog.thermwood.com/topic/history)
- [HLP (2)](https://blog.thermwood.com/topic/hlp)
- [Home Depot (1)](https://blog.thermwood.com/topic/home-depot)
- [Hotel Information (1)](https://blog.thermwood.com/topic/hotel-information)
- [i-cut (3)](https://blog.thermwood.com/topic/i-cut)
- [Impact Resistant Head (2)](https://blog.thermwood.com/topic/impact-resistant-head)
- [Impressions (3)](https://blog.thermwood.com/topic/impressions)
- [IMTS (3)](https://blog.thermwood.com/topic/imts)
- [Incentive (2)](https://blog.thermwood.com/topic/incentive)
- [Indiana (2)](https://blog.thermwood.com/topic/indiana)
- [Info Spot (5)](https://blog.thermwood.com/topic/info-spot)
- [injection molding (1)](https://blog.thermwood.com/topic/injection-molding)
- [Insert Tooling, (1)](https://blog.thermwood.com/topic/insert-tooling)
- [International Sign Expo (4)](https://blog.thermwood.com/topic/international-sign-expo)
- [Interns (1)](https://blog.thermwood.com/topic/interns)
- [Interview (1)](https://blog.thermwood.com/topic/interview)
- [introduction (3)](https://blog.thermwood.com/topic/introduction)
- [IPE (1)](https://blog.thermwood.com/topic/ipe)
- [ISA (1)](https://blog.thermwood.com/topic/isa)
- [italy (1)](https://blog.thermwood.com/topic/italy)
- [IWF (16)](https://blog.thermwood.com/topic/iwf)
- [Jamboree (1)](https://blog.thermwood.com/topic/jamboree)
- [jason susnjara (2)](https://blog.thermwood.com/topic/jason-susnjara)
- [JEC Americas (1)](https://blog.thermwood.com/topic/jec-americas)
- [JEC World (3)](https://blog.thermwood.com/topic/jec-world)
- [john cox (2)](https://blog.thermwood.com/topic/john-cox)
- [joinery (1)](https://blog.thermwood.com/topic/joinery)
- [Jumping (1)](https://blog.thermwood.com/topic/jumping)
- [Kansas (2)](https://blog.thermwood.com/topic/kansas)
- [Kansas City (1)](https://blog.thermwood.com/topic/kansas-city)
- [KCD (1)](https://blog.thermwood.com/topic/kcd)
- [Ken Susnjara (8)](https://blog.thermwood.com/topic/ken-susnjara)
- [Kentucky (1)](https://blog.thermwood.com/topic/kentucky)
- [King Starboard (1)](https://blog.thermwood.com/topic/king-starboard)
- [Kustom King Inc (1)](https://blog.thermwood.com/topic/kustom-king-inc)
- [Labels (3)](https://blog.thermwood.com/topic/labels)
- [Large Scale (13)](https://blog.thermwood.com/topic/large-scale)
- [Las Vegas (5)](https://blog.thermwood.com/topic/las-vegas)
- [laser scanning (1)](https://blog.thermwood.com/topic/laser-scanning)
- [Layer Time Control (1)](https://blog.thermwood.com/topic/layer-time-control)
- [Layered DXF (1)](https://blog.thermwood.com/topic/layered-dxf)
- [Learining (1)](https://blog.thermwood.com/topic/learining)
- [LFAM (8)](https://blog.thermwood.com/topic/lfam)
- [LFM (1)](https://blog.thermwood.com/topic/lfm)
- [Limited Time (1)](https://blog.thermwood.com/topic/limited-time)
- [Link (2)](https://blog.thermwood.com/topic/link)
- [List (1)](https://blog.thermwood.com/topic/list)
- [Live (1)](https://blog.thermwood.com/topic/live)
- [Live Demonstrations (11)](https://blog.thermwood.com/topic/live-demonstrations)
- [Local Motors (3)](https://blog.thermwood.com/topic/local-motors)
- [lock dado (1)](https://blog.thermwood.com/topic/lock-dado)
- [Loewer (1)](https://blog.thermwood.com/topic/loewer)
- [Low Cost (5)](https://blog.thermwood.com/topic/low-cost)
- [LSAM (57)](https://blog.thermwood.com/topic/lsam)
- [LSAM 1010 (3)](https://blog.thermwood.com/topic/lsam-1010)
- [LSAM 1020 (13)](https://blog.thermwood.com/topic/lsam-1020)
- [LSAM Additive Printers (12)](https://blog.thermwood.com/topic/lsam-additive-printers)
- [LSAM AP (3)](https://blog.thermwood.com/topic/lsam-ap)
- [LSAM MT (4)](https://blog.thermwood.com/topic/lsam-mt)
- [LSAM Print 3D (1)](https://blog.thermwood.com/topic/lsam-print-3d)
- [LSAM1540 (1)](https://blog.thermwood.com/topic/lsam1540)
- [M400 (1)](https://blog.thermwood.com/topic/m400)
- [Machining (3)](https://blog.thermwood.com/topic/machining)
- [Makor (1)](https://blog.thermwood.com/topic/makor)
- [manufacturing (12)](https://blog.thermwood.com/topic/manufacturing)
- [Marine Tooling (2)](https://blog.thermwood.com/topic/marine-tooling)
- [Mastercam (1)](https://blog.thermwood.com/topic/mastercam)
- [Material Flexibility (1)](https://blog.thermwood.com/topic/material-flexibility)
- [MAX5 (1)](https://blog.thermwood.com/topic/max5)
- [MDF doors (7)](https://blog.thermwood.com/topic/mdf-doors)
- [medical (2)](https://blog.thermwood.com/topic/medical)
- [melamine (1)](https://blog.thermwood.com/topic/melamine)
- [Melt Core (2)](https://blog.thermwood.com/topic/melt-core)
- [metal molds (1)](https://blog.thermwood.com/topic/metal-molds)
- [Microvellum (1)](https://blog.thermwood.com/topic/microvellum)
- [military (1)](https://blog.thermwood.com/topic/military)
- [millwork (2)](https://blog.thermwood.com/topic/millwork)
- [mobile (1)](https://blog.thermwood.com/topic/mobile)
- [Model 40 (2)](https://blog.thermwood.com/topic/model-40)
- [Model 41 (2)](https://blog.thermwood.com/topic/model-41)
- [Model 42 (5)](https://blog.thermwood.com/topic/model-42)
- [Model 43 (24)](https://blog.thermwood.com/topic/model-43)
- [Model 43 Work Cell (1)](https://blog.thermwood.com/topic/model-43-work-cell)
- [Model 45 (37)](https://blog.thermwood.com/topic/model-45)
- [Model 53 (2)](https://blog.thermwood.com/topic/model-53)
- [Model 63 (5)](https://blog.thermwood.com/topic/model-63)
- [Model 67 (13)](https://blog.thermwood.com/topic/model-67)
- [Model 70 (8)](https://blog.thermwood.com/topic/model-70)
- [Model 77 (11)](https://blog.thermwood.com/topic/model-77)
- [Model 90 (20)](https://blog.thermwood.com/topic/model-90)
- [Mold (2)](https://blog.thermwood.com/topic/mold)
- [moldings (9)](https://blog.thermwood.com/topic/moldings)
- [molds (7)](https://blog.thermwood.com/topic/molds)
- [Monitoring (4)](https://blog.thermwood.com/topic/monitoring)
- [MTR (6)](https://blog.thermwood.com/topic/mtr)
- [MTR 21 (2)](https://blog.thermwood.com/topic/mtr-21)
- [MTR 30 (2)](https://blog.thermwood.com/topic/mtr-30)
- [MTR 30DT (3)](https://blog.thermwood.com/topic/mtr-30dt)
- [MTR 36 (1)](https://blog.thermwood.com/topic/mtr-36)
- [Murphy Beds (1)](https://blog.thermwood.com/topic/murphy-beds)
- [Navair (2)](https://blog.thermwood.com/topic/navair)
- [Naval Surface Warfare (2)](https://blog.thermwood.com/topic/naval-surface-warfare)
- [Navy (3)](https://blog.thermwood.com/topic/navy)
- [NC (2)](https://blog.thermwood.com/topic/nc)
- [NEMI (1)](https://blog.thermwood.com/topic/nemi)
- [nest around defects (1)](https://blog.thermwood.com/topic/nest-around-defects)
- [Nested Base (22)](https://blog.thermwood.com/topic/nested-base)
- [nested based (19)](https://blog.thermwood.com/topic/nested-based)
- [Nested Based Work Cell (2)](https://blog.thermwood.com/topic/nested-based-work-cell)
- [Nesting Sheets (1)](https://blog.thermwood.com/topic/nesting-sheets)
- [New (19)](https://blog.thermwood.com/topic/new)
- [News (4)](https://blog.thermwood.com/topic/news)
- [No Programming (19)](https://blog.thermwood.com/topic/no-programming)
- [Olli (1)](https://blog.thermwood.com/topic/olli)
- [Omal (1)](https://blog.thermwood.com/topic/omal)
- [on-screen (1)](https://blog.thermwood.com/topic/on-screen)
- [online (2)](https://blog.thermwood.com/topic/online)
- [online store (1)](https://blog.thermwood.com/topic/online-store)
- [Open House (1)](https://blog.thermwood.com/topic/open-house)
- [optimize (1)](https://blog.thermwood.com/topic/optimize)
- [Option (1)](https://blog.thermwood.com/topic/option)
- [Options (6)](https://blog.thermwood.com/topic/options)
- [Original Woodworking (1)](https://blog.thermwood.com/topic/original-woodworking)
- [Orlando (3)](https://blog.thermwood.com/topic/orlando)
- [orthotics (1)](https://blog.thermwood.com/topic/orthotics)
- [Outdoor Cabinets (1)](https://blog.thermwood.com/topic/outdoor-cabinets)
- [Owners (2)](https://blog.thermwood.com/topic/owners)
- [panel processing (2)](https://blog.thermwood.com/topic/panel-processing)
- [panel saws (2)](https://blog.thermwood.com/topic/panel-saws)
- [Partnership (2)](https://blog.thermwood.com/topic/partnership)
- [Patented (8)](https://blog.thermwood.com/topic/patented)
- [Pattern (2)](https://blog.thermwood.com/topic/pattern)
- [patterns (4)](https://blog.thermwood.com/topic/patterns)
- [Performance (1)](https://blog.thermwood.com/topic/performance)
- [Personal Pause Button (3)](https://blog.thermwood.com/topic/personal-pause-button)
- [PETG (1)](https://blog.thermwood.com/topic/petg)
- [PH50 (1)](https://blog.thermwood.com/topic/ph50)
- [Phenolic (1)](https://blog.thermwood.com/topic/phenolic)
- [Picture Frames (1)](https://blog.thermwood.com/topic/picture-frames)
- [Planit (1)](https://blog.thermwood.com/topic/planit)
- [plastic trimming (3)](https://blog.thermwood.com/topic/plastic-trimming)
- [plastics (9)](https://blog.thermwood.com/topic/plastics)
- [pod system (1)](https://blog.thermwood.com/topic/pod-system)
- [Point of Purchase (3)](https://blog.thermwood.com/topic/point-of-purchase)
- [polhemus (2)](https://blog.thermwood.com/topic/polhemus)
- [Polk Area Bicycle Association (1)](https://blog.thermwood.com/topic/polk-area-bicycle-association)
- [Polysulfone (1)](https://blog.thermwood.com/topic/polysulfone)
- [Porosity (1)](https://blog.thermwood.com/topic/porosity)
- [ppe (1)](https://blog.thermwood.com/topic/ppe)
- [PPS (1)](https://blog.thermwood.com/topic/pps)
- [Pre-Drill (1)](https://blog.thermwood.com/topic/pre-drill)
- [Pre-Owned (1)](https://blog.thermwood.com/topic/pre-owned)
- [pressure forming (1)](https://blog.thermwood.com/topic/pressure-forming)
- [Prize (1)](https://blog.thermwood.com/topic/prize)
- [Process & Production Equipment (4)](https://blog.thermwood.com/topic/process-production-equipment)
- [Product Information (15)](https://blog.thermwood.com/topic/product-information)
- [Production Sharing (1)](https://blog.thermwood.com/topic/production-sharing)
- [Productivity (11)](https://blog.thermwood.com/topic/productivity)
- [Profile Modeler (4)](https://blog.thermwood.com/topic/profile-modeler)
- [Promotions (7)](https://blog.thermwood.com/topic/promotions)
- [Prosperous New Year (1)](https://blog.thermwood.com/topic/prosperous-new-year)
- [prosthetics (1)](https://blog.thermwood.com/topic/prosthetics)
- [PSU (1)](https://blog.thermwood.com/topic/psu)
- [Publisher (4)](https://blog.thermwood.com/topic/publisher)
- [Purchase (5)](https://blog.thermwood.com/topic/purchase)
- [Purdue (9)](https://blog.thermwood.com/topic/purdue)
- [Puzzle Joint (1)](https://blog.thermwood.com/topic/puzzle-joint)
- [pvc (2)](https://blog.thermwood.com/topic/pvc)
- [QCore (14)](https://blog.thermwood.com/topic/qcore)
- [QuickCut (7)](https://blog.thermwood.com/topic/quickcut)
- [Race Car (1)](https://blog.thermwood.com/topic/race-car)
- [Radius Crown Molding (1)](https://blog.thermwood.com/topic/radius-crown-molding)
- [RAPID + TCT (2)](https://blog.thermwood.com/topic/rapid-tct)
- [Reasons (1)](https://blog.thermwood.com/topic/reasons)
- [Recap (3)](https://blog.thermwood.com/topic/recap)
- [Recommendations (1)](https://blog.thermwood.com/topic/recommendations)
- [Refurbished (1)](https://blog.thermwood.com/topic/refurbished)
- [Reliable (1)](https://blog.thermwood.com/topic/reliable)
- [Remote Control (1)](https://blog.thermwood.com/topic/remote-control)
- [Retirement (4)](https://blog.thermwood.com/topic/retirement)
- [Retrofit (1)](https://blog.thermwood.com/topic/retrofit)
- [Review (1)](https://blog.thermwood.com/topic/review)
- [Rind Routing (3)](https://blog.thermwood.com/topic/rind-routing)
- [Roller Hold Down (1)](https://blog.thermwood.com/topic/roller-hold-down)
- [Router-CIM (1)](https://blog.thermwood.com/topic/router-cim)
- [RouterCAD (1)](https://blog.thermwood.com/topic/routercad)
- [RTA Cabinets (1)](https://blog.thermwood.com/topic/rta-cabinets)
- [RUAG (2)](https://blog.thermwood.com/topic/ruag)
- [SABIC (6)](https://blog.thermwood.com/topic/sabic)
- [safety (1)](https://blog.thermwood.com/topic/safety)
- [SAMPE (3)](https://blog.thermwood.com/topic/sampe)
- [sanders (1)](https://blog.thermwood.com/topic/sanders)
- [Satellite (1)](https://blog.thermwood.com/topic/satellite)
- [save material (2)](https://blog.thermwood.com/topic/save-material)
- [Save Money (7)](https://blog.thermwood.com/topic/save-money)
- [save money on cnc router (9)](https://blog.thermwood.com/topic/save-money-on-cnc-router)
- [Save Time (1)](https://blog.thermwood.com/topic/save-time)
- [savings (1)](https://blog.thermwood.com/topic/savings)
- [SCCA (1)](https://blog.thermwood.com/topic/scca)
- [Schedule 179 (1)](https://blog.thermwood.com/topic/schedule-179)
- [Scholarship (11)](https://blog.thermwood.com/topic/scholarship)
- [scrap (1)](https://blog.thermwood.com/topic/scrap)
- [scrap material (1)](https://blog.thermwood.com/topic/scrap-material)
- [sculptures (2)](https://blog.thermwood.com/topic/sculptures)
- [Service (7)](https://blog.thermwood.com/topic/service)
- [Shaker (2)](https://blog.thermwood.com/topic/shaker)
- [Shapes (2)](https://blog.thermwood.com/topic/shapes)
- [Shipping Machines (1)](https://blog.thermwood.com/topic/shipping-machines)
- [Shopbot (3)](https://blog.thermwood.com/topic/shopbot)
- [ShopWare CAD (1)](https://blog.thermwood.com/topic/shopware-cad)
- [Sign (4)](https://blog.thermwood.com/topic/sign)
- [sign industry (5)](https://blog.thermwood.com/topic/sign-industry)
- [SignRouter 43 (6)](https://blog.thermwood.com/topic/signrouter-43)
- [signs (4)](https://blog.thermwood.com/topic/signs)
- [Simulation (1)](https://blog.thermwood.com/topic/simulation)
- [skf enterprises (1)](https://blog.thermwood.com/topic/skf-enterprises)
- [Skills (2)](https://blog.thermwood.com/topic/skills)
- [smart (4)](https://blog.thermwood.com/topic/smart)
- [smart-router (26)](https://blog.thermwood.com/topic/smart-router)
- [smart-router series (5)](https://blog.thermwood.com/topic/smart-router-series)
- [software (14)](https://blog.thermwood.com/topic/software)
- [software update (21)](https://blog.thermwood.com/topic/software-update)
- [solid surface (1)](https://blog.thermwood.com/topic/solid-surface)
- [Solid Wood (2)](https://blog.thermwood.com/topic/solid-wood)
- [solid wood processing (2)](https://blog.thermwood.com/topic/solid-wood-processing)
- [Special (2)](https://blog.thermwood.com/topic/special)
- [Spiceland Wood Products (1)](https://blog.thermwood.com/topic/spiceland-wood-products)
- [Spirit Aerosystems (1)](https://blog.thermwood.com/topic/spirit-aerosystems)
- [spoilboard (2)](https://blog.thermwood.com/topic/spoilboard)
- [Sponsor (1)](https://blog.thermwood.com/topic/sponsor)
- [SR43 (4)](https://blog.thermwood.com/topic/sr43)
- [ST Engineering (1)](https://blog.thermwood.com/topic/st-engineering)
- [Stimulus (3)](https://blog.thermwood.com/topic/stimulus)
- [Straight Talk (2)](https://blog.thermwood.com/topic/straight-talk)
- [Strati (1)](https://blog.thermwood.com/topic/strati)
- [Streaming (1)](https://blog.thermwood.com/topic/streaming)
- [Student (1)](https://blog.thermwood.com/topic/student)
- [Submarine (1)](https://blog.thermwood.com/topic/submarine)
- [substrates (3)](https://blog.thermwood.com/topic/substrates)
- [Subtractive (2)](https://blog.thermwood.com/topic/subtractive)
- [Success Story (1)](https://blog.thermwood.com/topic/success-story)
- [super controller (4)](https://blog.thermwood.com/topic/super-controller)
- [SuperControl (7)](https://blog.thermwood.com/topic/supercontrol)
- [Support (8)](https://blog.thermwood.com/topic/support)
- [T16 (1)](https://blog.thermwood.com/topic/t16)
- [TAHOE Boats (1)](https://blog.thermwood.com/topic/tahoe-boats)
- [Tax (2)](https://blog.thermwood.com/topic/tax)
- [tax incentive (2)](https://blog.thermwood.com/topic/tax-incentive)
- [Tech Con (6)](https://blog.thermwood.com/topic/tech-con)
- [Techmer PM (6)](https://blog.thermwood.com/topic/techmer-pm)
- [Technology (21)](https://blog.thermwood.com/topic/technology)
- [Test Results (2)](https://blog.thermwood.com/topic/test-results)
- [Testimonials (10)](https://blog.thermwood.com/topic/testimonials)
- [Testing (1)](https://blog.thermwood.com/topic/testing)
- [Texas (1)](https://blog.thermwood.com/topic/texas)
- [Thanks (9)](https://blog.thermwood.com/topic/thanks)
- [thermoforming (2)](https://blog.thermwood.com/topic/thermoforming)
- [Thermographic (1)](https://blog.thermwood.com/topic/thermographic)
- [Thermwood (336)](https://blog.thermwood.com/topic/thermwood)
- [Thermwood Family (1)](https://blog.thermwood.com/topic/thermwood-family)
- [Thermwood India (1)](https://blog.thermwood.com/topic/thermwood-india)
- [Thermwood LSAM (52)](https://blog.thermwood.com/topic/thermwood-lsam)
- [Thermwood LSAM Research Laboratory (2)](https://blog.thermwood.com/topic/thermwood-lsam-research-laboratory)
- [tigerstop (1)](https://blog.thermwood.com/topic/tigerstop)
- [Timberwood Properties (1)](https://blog.thermwood.com/topic/timberwood-properties)
- [Timelapse (1)](https://blog.thermwood.com/topic/timelapse)
- [Timesavers (1)](https://blog.thermwood.com/topic/timesavers)
- [tips (2)](https://blog.thermwood.com/topic/tips)
- [Tool Length Sensor (1)](https://blog.thermwood.com/topic/tool-length-sensor)
- [tooling (6)](https://blog.thermwood.com/topic/tooling)
- [Total Solution (3)](https://blog.thermwood.com/topic/total-solution)
- [Tour (4)](https://blog.thermwood.com/topic/tour)
- [Traco Manufacturing (1)](https://blog.thermwood.com/topic/traco-manufacturing)
- [Trade Shows (47)](https://blog.thermwood.com/topic/trade-shows)
- [Training (6)](https://blog.thermwood.com/topic/training)
- [trimming (6)](https://blog.thermwood.com/topic/trimming)
- [Trump (1)](https://blog.thermwood.com/topic/trump)
- [Updated Features (9)](https://blog.thermwood.com/topic/updated-features)
- [US made (4)](https://blog.thermwood.com/topic/us-made)
- [Used (1)](https://blog.thermwood.com/topic/used)
- [V-Line Corporation (1)](https://blog.thermwood.com/topic/v-line-corporation)
- [vacuum (2)](https://blog.thermwood.com/topic/vacuum)
- [vacuum forming (1)](https://blog.thermwood.com/topic/vacuum-forming)
- [veneer (1)](https://blog.thermwood.com/topic/veneer)
- [Vericut (1)](https://blog.thermwood.com/topic/vericut)
- [Vertical Layer Printing (2)](https://blog.thermwood.com/topic/vertical-layer-printing)
- [Vertical Wall Beds (2)](https://blog.thermwood.com/topic/vertical-wall-beds)
- [Video (56)](https://blog.thermwood.com/topic/video)
- [virtual (1)](https://blog.thermwood.com/topic/virtual)
- [virtual service (4)](https://blog.thermwood.com/topic/virtual-service)
- [virtual tour (3)](https://blog.thermwood.com/topic/virtual-tour)
- [VLP (6)](https://blog.thermwood.com/topic/vlp)
- [Voids (1)](https://blog.thermwood.com/topic/voids)
- [Vortex (1)](https://blog.thermwood.com/topic/vortex)
- [Web Demos (5)](https://blog.thermwood.com/topic/web-demos)
- [Website (1)](https://blog.thermwood.com/topic/website)
- [White River (1)](https://blog.thermwood.com/topic/white-river)
- [Why LSAM (1)](https://blog.thermwood.com/topic/why-lsam)
- [Why Purchase a Thermwood (11)](https://blog.thermwood.com/topic/why-purchase-a-thermwood)
- [Wind Energy (2)](https://blog.thermwood.com/topic/wind-energy)
- [Winner (2)](https://blog.thermwood.com/topic/winner)
- [WMS (2)](https://blog.thermwood.com/topic/wms)
- [WMS Show (5)](https://blog.thermwood.com/topic/wms-show)
- [wood (6)](https://blog.thermwood.com/topic/wood)
- [wood carving (4)](https://blog.thermwood.com/topic/wood-carving)
- [Woodsong Cabinet & Trim (2)](https://blog.thermwood.com/topic/woodsong-cabinet-trim)
- [Woodworking (28)](https://blog.thermwood.com/topic/woodworking)
- [World's Largest 3D Composite 3D Printer (1)](https://blog.thermwood.com/topic/worlds-largest-3d-composite-3d-printer)
- [Wyoming (1)](https://blog.thermwood.com/topic/wyoming)
- [Yacht (1)](https://blog.thermwood.com/topic/yacht)
- [YouBuild (11)](https://blog.thermwood.com/topic/youbuild)
[See all](https://blog.thermwood.com/thermwood-unveils-a-new-additive-way-to-make-metal-molds-blog-10-23-23#)
### Most Popular Posts
[![Bookmark and Share](http://s7.addthis.com/static/btn/lg-share-en.gif)](http://www.addthis.com/bookmark.php)
[![Add to Technorati Favorites](http://static.technorati.com/pix/fave/tech-fav-1.png)](http://technorati.com/faves?sub=addfavbtn&add=http://blog.thermwood.com)
[![Business Blogs - Blog Catalog Blog Directory](http://assets.blogcatalog.com/buttons/blogcatalog4.gif)](http://www.blogcatalog.com/directory/business)
- [Thermwood Corporation Blog](https://blog.thermwood.com/)
- [Thermwood Home Page](http://www.thermwood.com/index.html)
- [Contact Us](http://www.thermwood.com/contact.htm)
© Thermwood Corporation. All Rights Reserved
![Quantcast](http://pixel.quantserve.com/pixel/p-ef0KmNPVclx2A.gif)
```json
  "@context" : "https://schema.org",
  "@type" : "VideoObject",
  "caption" : {
    "@type" : "MediaObject",
    "contentUrl" : "https://blog.thermwood.com/media-transcripts/141821632181/en.vtt",
    "inLanguage" : "en",
    "name" : "en Captions"
  "contentUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/New%20Additive%20Way%20to%20Make%20Metal%20Molds.mp4",
  "dateModified" : "2025-09-04T18:38:58.682Z",
  "duration" : "PT12M38.508S",
  "height" : 1080,
  "name" : "New Additive Way to Make Metal Molds",
  "thumbnailUrl" : "https://41868.fs1.hubspotusercontent-na1.net/hubfs/41868/New%20Additive%20Way%20to%20Make%20Metal%20Molds.mp4/medium.jpg?t=1757011138682",
  "uploadDate" : "2023-10-24T19:43:46.231Z",
  "width" : 1920
