Large Sculptures created on a Thermwood 5 Axis Model 67 CNC Router at John Cox's Creature Workshop
Posted by Duane Marrett on Thu, Oct 08, 2015
Tags: 5 Axis, CNC Router, Model 67, john cox, sculptures, 67
M67DT5x12QC_lg-resized-600
Model 67 5'x12' Dual Table CNC Router shown
Description:
The Model 67 is entry-level fixed-gantry, moving table 5 Axis CNC router that is used for trimming formed parts, patterns or molds using five-axis simultaneous motions.  It is available with a variety of either single or dual moving solid aluminum table sizes.
Features of the Model 67:
  • Single table sizes from 5'x5' to 10'x5' or dual table sizes from 5'x5' to 5'x12'
  • Fixed Gantry
  • Moving Solid Aluminum Table
  • 7.5HP HSD Dual End Spindle (3,000-18,000RPM)
  • 24' Z axis standard (available up to 48" Z axis)
  • QCore SuperControl
  • Full 5 axis simultaneous motions
  • Siemens Intelligent Servo Drives Throughout
  • 3D Laser Compensated Axis Alignment
  • Automatic Tool Length Sensor (optional)
  • Free Lifetime Phone/Forum Support
Videos featuring large sculptures created on a Thermwood Model 67 at John Cox's Creature Workshop:
Thermwood Model 77 for Large Format Composite, Aerospace, Pattern/Mold Machining
Posted by Duane Marrett on Wed, Sep 16, 2015
Tags: Thermwood, CNC, 5 Axis, Announcements, CNC Router, Model 77, manufacturing
The Thermwood Multi-Purpose Five Axis Series combines all the elements needed for trimming of large aerospace and composite materials as well as machining large format patterns and molds/plugs for the aviation and defense industries.
Here we look at the Thermwood Model 77.  This heavy-duty, high-speed, moving gantry machine is ideal for machining large applications utilizing heavy fixtures.
Lenny and Mike with their newly installed Thermwood Model 77 5'x10' 5 Axis CNC Router
Lenny and Mike with their newly installed Model 77 5’x10’ 5 Axis CNC router featuring an enclosed overhead cap cover, 10 position rotary automatic tool changer, 36" Z Axis, gantry lighting system, access doors, Nemi pod table and rear dust extraction booth.
Thermwood Model 77 5x10 CNC Router
Features:
  • 12HP HSD Tool Change Spindle (3,000-24,000 RPM Spindle) (other spindles available)
  • Impact Resistant 5 Axis Head
  • 36" Z (other sizes available)
  • 10 Position Rotary Tool Change System
  • Full 5 Axis Simultaneous Motion
  • Fixed Drill and Tapped Aluminum Table
  • Conventional Style Vacuum Plumbing
  • Heavy Duty Access Doors
  • Gantry Lighting
  • Overhead Cover Cap
  • Rear Dust Extraction Booth
  • Tool Center Point Programming (TCP)
  • Rapid Speed: 3500 inches per minute
  • Moving Gantry
  • Thermwood Q Core SuperControl
  • Volumetric 3D Laser Compensated Axis Alignment
  • Chip Collection
  • Multi-Function Nemi Pod Table
Model 77 Options
Thermwood Model 70 and 77 for Large Format Aerospace, Composite, Pattern and Mold Machining
Posted by Duane Marrett on Thu, Feb 05, 2015
Tags: CNC, Composites, 5 Axis, CNC Router, aerospace, Model 70, Model 77, trimming, molds, patterns
The Thermwood Multi-Purpose Five Axis Series combines all the elements needed for the machining of large aerospace and composite materials as well as trimming and machining large format patterns and molds/plugs for the aviation and defense industries.
Here we look at the Thermwood Model 77 and Model 70.  These heavy-duty, high-speed, moving gantry machines are ideal for machining of large applications using large/heavy fixtures.
Multi-Purpose 77
The Multi-Purpose 77 is a heavy-duty, high-speed contained system for the machining of large aerospace and composite materials (various sizes available):
Features:
  • Moving Gantry
  • Chip Collection
Model 77 10x20 Fixed Table
Videos (please click images to view videos on our blog)
Multi-Purpose 70
The Multi-Purpose 70 is designed for aerospace and composite applications utilizing large/heavy fixtures (various sizes available):
Features:
  • 12HP HSD Tool Changer Spindle (3,000-24,000 RPM larger spindle sizes available)
  • Fixed Aluminum Table
  • Moving Gantry
  • 24" Z Standard (available up to 60")
  • Thermwood QCore SuperControl
  • Chip Collection System
  • In the Leg Tool Changer
  • Bar Style Tool Changer
  • Automatic Lubrication
Thermwood Model 70 10x20 CNC Router
Model 70 10x20 Fixed Table
Thermwood Model 70 10x10 CNC Router
Model 70 10x10 Fixed Table
More Info
To find out more about either of these two machines, or any of our other 5 axis offerings, please give us a call at 1-800-533-6901 or click below to fill out an information request form.  We hope to hear from you soon!
Thermwood Model 67 and 90 for Trimming, Molds & Pattern Machining
Posted by Duane Marrett on Wed, Jan 21, 2015
Tags: CNC, 5 Axis, CNC Router, Model 90, Model 67, trimming, molds, patterns
The Thermwood Multi-Purpose Five Axis Series combines all the elements needed for trimming formed parts, patterns and molds using five-axis simultaneous motions.
Here we look at the Thermwood Model 67 and 90.  These heavy-duty moving-table machines are ideal for high-speed trimming and pattern machining, and come in either single or dual table configurations:
Multi-Purpose 67
The Multi-Purpose 67 is an entry-level five axis available with a variety of either single or dual moving aluminum table sizes.
Features:
  • 12HP HSD Tool Change Spindle (3,000-24,000 RPM, larger spindle sizes available)
  • Impact Resistant Head
  • Moving Aluminum Table/Fixed Gantry
  • 24" Z Standard (available up to 48")
  • Chip Collection
  • Remote Start/Stop
  • Gantry Lighting
Thermwood Model 67 7x10 CNC Router
Model 67 7x10 Single Moving Table
Thermwood Model 67 10x5 CNC Router
Model 67 5x10 Dual Moving Tables
Videos
Multi-Purpose 90
The Multi-Purpose 90 is a heavy-duty five-axis designed for high-speed trimming and pattern machining, available in single or dual moving aluminum tables.
Features:
  • Fixed Gantry
  • Chip Collection
Thermwood Model 90 5x12 Dual Table CNC Router
Model 90 5x12 Dual Moving Tables
Thermwood Model 90 10x5 CNC Router
Model 90 10x5 Single Moving Table
Videos
More Info
Free Live Demonstrations at Thermwood
Posted by Duane Marrett on Fri, Oct 03, 2014
Tags: Thermwood, 3 Axis, 5 Axis, Demonstrations
demo_overviewThermwood's Demonstration Center is available for free live demonstrations at our modern factory headquarters in Dale, IN.  During your demo you can expect:
  • We will replicate your exact part(s) and show you how we can increase your productivity, while saving you money and time on a Thermwood CNC router.
  • Work with our CNC Experts in depth on your exact application(s), and ask questions about programming, machine operation, options, maintenance, financing, service and support.
  • See our manufacturing process from start to finish, and how we carefully build each machine from the ground up.
  • demo_overview_2Tour our facility to see our modern training center (where each machine purchase comes with a 1 week training class for two), factory and demonstration center.
  • See a wide variety of our machines, both three and five axis in action as well as the 2014 Challenger Award winning Cut Ready Cut Center.
  • We will record a video of your live demo for you to watch later.
m90_demo-1
Model 90 5 Axis Dual Table 5x5 CNC Router in our Demo Center
 model_45_2
Model 45 3 Axis 5x10 CNC Router in our Demo Center
 CUT_CENTER
Cut Ready Cut Center 5x10 in our Demo Center (winner of a 2014 IWF Challenger's Award)
 model_43_1
Model 43 3 Axis CNC Router 5x10 with Auto-Offload in our Demo Center
Kitchen cabinet design from IWF 2014 Thermwood booth - all made on a Cut Center
See examples of what our machines can make - Kitchen Design made entirely on a Cut Center
Web Demos
We also offer live Web Demos that allow you to interact with our Demonstration department via your computer.  These web demos are available for both the latest software solutions as well as our machines.  You can see the machine and control running your application and ask questions in real time.
If time or travel is a factor, this might be a good first step to see what our machines can do for you, before you come in and see the process in person.  Our local representative is typically on-site at your facility during these demonstrations to help explain the process and answer any questions you may have.
webex_screenshot_cut_center
Request More Info
Click to request More Info on a Free live Demo from Thermwood!
Thermwood 5 Axis Multi-Purpose CNC Routers
Posted by Duane Marrett on Fri, May 16, 2014
Tags: CNC Routers, 5 Axis, Technology, CNC Router, Model 90, Model 67, aerospace, Model 70, Model 77
The Thermwood Multi-Purpose Five Axis Series combines all the elements needed for trimming formed parts, patterns or molds using five-axis simultaneous motions.
Whether you are interested in a moving table machine for high-speed trimming, a fixed table for large aerospace and composite fixtures or a high-wall machine, we have a solution for you:
Multi-Purpose 67
Videos
Multi-Purpose 90
Videos
Multi-Purpose 70
The Multi-Purpose 70 is designed for aerospace and composite applications utilizing large/heavy fixtures (various sizes available).
Video
Multi-Purpose 77
The Multi-Purpose 77 is a heavy-duty, high-speed contained system for the machining of large aerospace and composite materials (various sizes available).
Videos
More Info
New Option for Model 70 - 10 Position Automatic Rotary Tool Changer
Posted by Duane Marrett on Tue, Apr 29, 2014
Tags: Thermwood, New, 5 Axis, Announcements, Model 70, 2014, Option, Retrofit
A new option is now available for the Thermwood Model 70 CNC Router - A 10 Position Automatic Rotary Tool Changer.
This new tool changer is contained in a protective housing that moves forward when tool changes are needed, and then back out of the working area to continue machining.  It expands the Model 70's capabilities with an additional 10 tooling positions.
Video
Images
Model 70 10 Position Rotary Tool Changer
Model 70 10 Position Rotary Tool Changer - Open
More Info
The 10 Position Automatic Rotary Tool Changer can be added to a new Model 70 as an option, or retrofitted to an existing machine.  Please Contact Thermwood Retrofits for more information on adding this option to your existing Model 70.
About the Model 70
The Thermwood Model 70 is designed for aerospace and composite applications utilizing large/heavy fixtures (various table sizes are available).
Which Type of CNC Router Training is Right For You?
Posted by Duane Marrett on Thu, Apr 24, 2014
Tags: CNC, CNC Routers, 3 Axis, 5 Axis, CNC Router, Training, Support, education
CNC Router Training Options
After weeks, months and sometimes years of deliberation, you've finally decided that a CNC Router is right for your business!  One of the most important (but often forgotten) aspects of a CNC Router purchase that businesses don’t think about is training.  If this is your first CNC Router purchase, then training is key.  Choosing a router that offers a comprehensive training schedule is important so you can be prepared when the router arrives at your facility.
Almost every CNC Router manufacturer offers some form of training, and each has its positives and negatives.  Some allow five full days of dedicated in-house training at their facility, while others offer two days of training at your facility in combination with your machine install/setup.
What is Onsite Training?
Onsite CNC TrainingOnsite training is generally one to two days at your facility performed by a technician who not only will train you but will also run power to the machine and set it up.  Some of the training should include maintenance routines.  Onsite training is nice for those businesses that find it hard to get away from the office for a short period of time or having to spend extra on travel expenses (but this scenario also gives you less training time).  During this training period, distractions and interruptions can and will occur due to daily business routines.
If you’re looking at a CNC Router that offers onsite training, ask the company for a training itinerary so you can get a better idea as to what they will be teaching you during this one to two days.
What is In-house Training?
Thermwood Training FacilitiesIn-house training is generally a longer period of time, usually no more than five days at the manufacturer's facility.  Added travel expense and time away from the shop for one or two of your employees could be hard for some of you, but you will receive more in depth training as well as no interruptions or distractions.  Some view the travel as a way to take a “vacation” or time away from the shop.
In-house training is performed by a dedicated instructor who teaches this information week in and week out.  Also, you would most likely be in a training class along with other businesses just like yours.  This method gives you and the other students a chance to take a tour of the manufacturers’ facility and possibly see your machine being assembled if it hasn’t been shipped yet.  Depending on the manufacturer, lunches are provided during the week, so students aren’t left wandering around looking for places to eat.
How about Software Training?
eCabinet Systems Online TrainingSoftware training is going to depend on who you purchase the software from.  Some offer onsite training, some in-house training and now (because of the popularity of the internet), online training is also available.  The pluses and negatives above will also apply to software training.  Hopefully you will have decided which software will work for your business before your new machine arrives, as this will give you an advantage of putting that CNC Router right to work once it is in place.  Online training allows you to go through the training courses anywhere/anytime and at your own pace as long as you have an internet connection.
Don't forget Training Support
Thermwood technician uses Virtual Service to help a customerAnother aspect to consider is training support.  If you have questions or concerns about your machine or its operation/programming, you want to go with a vendor who offers the easiest access to answers.  Some manufacturers have pay-for-answer support which charges by the answer or by a time period, while others have free forums, email and/or phone support.
The decision is yours!
You should spend time investigating all aspects of your purchase before you make a decision.  Ultimately, how well you understand your CNC Router and its operation (as well as the level of support you can expect) will help determine your future success.
Large Sculptures on a Thermwood 5 Axis Model 67 CNC Router
Posted by Duane Marrett on Thu, Nov 07, 2013
Tags: Thermwood, CNC Routers, 5 Axis, Model 67, Video, john cox, sculptures
This video shows a variety of large sculptures created on a Thermwood 5 Axis Model 67 CNC Router.  These were all done at John Cox's Creature Workshop in Queensland Australia.
The Model 67 is a fixed-gantry, moving table 5 Axis CNC Router that features single table sizes from 5'x5' to 10'x5' or dual table sizes from 5'x5' to 5'x12'.  It has a 7.5HP HSD Dual End Spindle (3,000-18,000RPM) and Z axis height up to 60".
Thermwood Model 67 5x12 Dual Table CNC Router
Thermwood Model 67 5'x12' Dual Table CNC Router shown
Click to Calculate your CNC Router Investment
Thermwood Five Axis Alignment Verification Routine
Posted by Duane Marrett on Thu, Mar 07, 2013
Tags: Thermwood, CNC, software, software update, Composites, CNC Routers, 5 Axis, Announcements, CNC Router, Model 90, aerospace, Model 70, Model 77, Video, QCore, SuperControl, introduction
Thermwood has developed our new Five Axis Alignment Verification Routine which is used to record and populate the alignment measurement values into the Thermwood QCore control system (after machine alignments are manually performed).
This routine automatically checks alignment in multiple axes and allows alignment to be quickly verified between jobs.  The routine compares the measured values to the default values.
The Thermwood 5 Axis Alignment Verification Routine includes:
  • Renishaw high-tolerance tooling sensor
  • Precision ground pin
  • Dedicated tool holder
  • Collet and all mounting hardware.
For more information on the Five Axis Alignment Verification Routine, please contact us at 1-800-533-6901.
