The Thermwood AutoProcessor is a high-speed, automatic load/unload, heavy-duty three-axis CNC routing system for nested based feed through machining. Available in a variety of machine table sizes, it is used in nested based production of cabinets, closets and custom furniture.
How it Works:
With each cycle, the machine simultaneously labels one sheet while positioning and machining the other sheet. It then off-loads the finished parts while loading the next sheet and repeats the process. Dust collection during this process keeps scrap and debris to a minimum.Labels help the operator to quickly sort the parts, and Assembly Marks help final assembly happen quickly and easily.
Thermwood AutoProcessor 5'x10' in a Customer's Shop:
Features of the Thermwood AutoProcessor:
- Various Table Sizes Available (5'x10', 5'x12' and 7''x12')
- Automatic Load/Unload System (6000 lb automatic lift table for loading and a steel offload/work table)
- 12HP (3,000-24,000 RPM) Spindle
- Universal Vacuum
- Rake w/Integrated Dust Collection
- Rapid Speed: 4100 Inches per minute
- Siemens Intelligent Servo Drives
- 3D Laser Compensated Axis Alignment
- 10 Position Rotary Automatic Changer
- Automatic Pop-Up Pins
- Automatic Tool Length Sensor
- Automatic Labeling System
- QCore SuperControl
- Machine Training and Installation
- Free Lifetime Phone/Forum Support
Drawings:
